4.0 rough idle diagnostic help
JJMaine
121
Maine
Ford Ranger XLT
Not sure because but if I remember there is an unorthodox test you can do. Something like start the truck and unplug it while idling and I guess if the idle changes drastically then you know it's working? You'ld have to look it up but it's something like that.
jballard81
Terminal Procrastinater
414
North Carolina
You are correct. If the IAC is working properly and you unplug it at idle your idle should drop some apparently. I will give it a shot tomorrow!
jballard81
414
North Carolina
unplugged the IAC while it was idling and the rpm's dropped just a bit. only really noticed it when i plugged it back in and the idle kicked up just a bit. So IAC appears to be good.
jballard81
414
North Carolina
@bobbywalter seeing as I didn't finish the leak down test for all cylinders, but the compression numbers are good is it a reasonable assumption to think it could be the injectors?
Or maybe there's a way to test them?
Thanks!
bobbywalter
TRS Technical Staff
Ugly Truck of Month
TRS 25th Anniversary
6,123
woodhaven mi
FORD mostly
BIGGER
sawzall?
hard to say. without testing the injectors.
jballard81
414
North Carolina
Snagged the reman Bosch injectors from eBay. Worth a shot seeing as they weren't too bad on the $$.
Give me a chance to inspect the valve covers for leaks as well.
RaceRanger97
December Truck of The Month
Vagabond Video
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
