INFO 4.0 OHV IDLE
akdsrtrat
Phoenix
Ranger XLT 4X
looking how to adjust idle speed, base idle and with ac on
franklin2
1,977
Virginia
The computer controls the idle speed. You can clean the throttle body and the idle air control valve, and the computer may control it better, but it has the last say in idle speed.
SenorNoob
TRS 25th Anniversary
1,183
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
What are you trying to fix? I'm sure someone has other ideas.
akdsrtrat
Phoenix
Ranger XLT 4X
Had the AC compressor replaced. Before hand the idle would go up maybe 200 RPM when AC was engaged, now no rpm increase. In my experience when ac activated the idle would go up to compensate for load. Am I wrong? TIA.
4.0blue98
I don't feel tardy...
738
Frederick, Maryland
4.0 OHV
Round
It was like that when I found it.
Mine barely changes. Definitely not 200 rpm. Might blip up at engagement but then drops right back down.
franklin2
1,977
Virginia
Hard to say how they have it programmed. If the compressor engages and the rpms stay the same, it is definitely compensating for the extra load. Is it supposed to increase the rpms above normal idle rpms? Not sure.
Cleaning the throttle body and the idle air control valve and passages always helps and should be a routine every 50K or so. That may let more air through and increase the idle rpms.
Rick W
October Truck of The Month
Vagabond Video
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
