Wirenut
- Oct 23, 2021
- 3
- US
- Ford Ranger
- Engine Type
- 4.0 V6
- 2WD / 4WD
- 2WD
I think it's about time I tackle what I hope to be the last part of my cooling system saga. Initially, the thermostat was stuck open so I changed it, the water pump, and hoses. That allowed the engine to heat up properly again but the increased pressure made the radiator leak and after replacing that, the intake gasket was the next weak point. Well, that's been done and the front cover decided it wanted it's turn. I've been losing coolant for a while now, enough to need a top-up every week or two, but haven't seen any leaks or puddles like I did when the intake gasket went out so I've put it off. Today, I had the front end jacked a bit and could see the coolant running from where the cover meets the block, which was a bit of a relief because I've started worrying that maybe there's an internal leak but the block test I did a while back was good so maybe I'm thinking too much about it.
Anyway, I've seen advice here and a watched few videos about replacing the cover seal without pulling the engine so I'll go that route. But since I'm there should I replace any timing components? At 329k, they're likely worse for wear but I don't have any noise from them, aside from a rattle when getting on the gas at too low an RPM. If I should change it I'd like to do it now but if it's something best left alone, all the better. Any opinions or experience with the OEM set's service life?
