4.0 missfire /bucking
wynnespeed
GA
1995 and 2000
2.3 and 4.0
So first off its a 00 ranger xl with. 4.0 with about 190000 miles.
It all started about a week ago my fiance drove it hoe from work and said it was running bad so I checked it out, from a cold start it sounds OK at idle but with a slight miss, then when u put it in gear it really runs bad kind of starts to buck. When u move on down the road it runs like crap til it gets to operating temp and go a few more miles it starts to smooth out.
Now it seems to be getting worse, this is what I've tried so far,
Heet in that gas
Mass air flow sensor
Coil pack
Wires and plugs are only a few months old
I put a 0s sensor in it cranked it up and brove it around the block and didn't help to I look it back out
I've checked air filter
Tightened intake hoses
Reset the computer a few times after replacing coil pack and mas
Also truck has small coolant leak from the vacuum thing the goes to the heater core.
Any ideas? THANKS FOR READING AND UR TIME
wynnespeed
GA
1995 and 2000
2.3 and 4.0
I put it on a scanner at work and I got a p0306 and like a p0141 and a p0136 I think that's what they were , anyway they were like bank 1 something to do with the o2 sensors and every one who's what a 306 is haha,
Just thought I'd add that
Maybe the cats are stopped up, because after only driving like 5 miles after turning her off it seems like it makes some louder than normal pinging coming from the exhaust.
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
Honestly sounds like an EGR valve problem...
wynnespeed
GA
1995 and 2000
2.3 and 4.0
Where is the egr on the 00s ranger. It doesn't look like a normal egr does it .
And thanks for the reply blinker88
wynnespeed
GA
1995 and 2000
2.3 and 4.0
I just checked and my truck don't have one its even been capped on the exhaust manifold
modelageek
14
Boston, MA
Those 2 codes are for your Bank 1 downstream sensor. That sensor should not be causing your issue. I would focus on the cylinder 6 misfire. Check the plug, wire, injector, compression, etc. I also would keep checking for codes.
wynnespeed
GA
1995 and 2000
2.3 and 4.0
The plug looks to be fine. I took off the 6 wire to see if it would change anything and it got alotworse . I thinking now that it might be a head gasket issue because there is some oily like stuff in the bottom of the coolant tank. And the oil on the dip stick is getting higher and a light brown ish color . Also when u start it it has a lot of white smock coming out the tail pipe than normal, I know its a little cold but still.
christw
Ohio
3.0 MT
Yeah, that might be a head gasket. Have you got a compression tester? When you pulled the plug was there any fluid in the cylinder? My truck had a cracked head when it bought it and those symptoms sound similar.
wynnespeed
GA
1995 and 2000
2.3 and 4.0
I took the intake (upper and lower) and they were nasty looking. . And when I got the valve covers off I find I oily milky mess.. although I have not got the heads off but everything on it seems too easy the remove even the exhaust manifold wasn't I pain, almost like someone has done it before on this truck.. I'm thinking the heads are cracked or worp. Good news is my buddy has a 4.0 out of a 92 exploder that I'm getting for dirt cheap. If I swap the intakes will there be any wiring issues?
