4.0 High Idle
Shikai2070
Vancouver B.C
Have a 92 ranger with a 4.0l. Dealing with a high idle issue. Around 1500rpm. Tried cleaning the IAC and it didnt seem to help. Can verify it moves when 12v is applied to it. If I unplug the iac the idle drops down to 1000 rpm or so.
Rock Auto 5% Discount Code: 7FA902352B4C01: April 5th, 2021
Eddo Rogue
324
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
I had a high idle issue, apparently its common on the 4.0, and could be many things. Mine turned out to be the throttle body. I taped the hole shut on the throttle plate and it dropped my idle nicely, so I filled it in with solder and drilled a smaller hole, idled and ran great until I was able to replace it.
Anyways if you want a quick test, you can try taping over the hole on the throttle plate and run it.
Shikai2070
Vancouver B.C
Will that cause issues? Shouldnt the hole be left open if its there by design?
PetroleumJunkie412
2.9 Mafia
4,726
Pittsburgh, PA
2.9l Trinity
You have a vacuum leak.
Propane test or smoke machine.
Eddo Rogue
324
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Well on mine I think the gap between the plate was compromised. making more air than usual pass thru when closed.
This was a diagnosis/temporary fix. I did replace it with a new one.
