4.0 Head gap tolerance?
RussAdams
50
Greater Washington, D.C. Metro area. USA
Ford Ranger XLT
4.0l V6 OHV "Cologne"
I put a straight edge on my heads today. They are off due to an intake manifold leak. I'd already loosened the driver head so in for a penny in for a pound.
The passenger side is great.
The driver's side head has a small gap on either side of the middle cylinder.
I can get a feeler gauge .005 under the straight edge, but not a .006.
Does anyone know the allowable tolerance?
Do I have it resurfaced or is it ok as-is?
Thanks everyone!
pentode
Well Known Cheapskate
581
Moncton NB
Old Alldata says .003 over a 6 inch span, .006 overall
pentode
581
Moncton NB
Assuming you used a full length straight edge, I’d say you should be good. I don’t have another manual at hand to double check but those numbers sound sane to me. Good luck!
pentode
581
Moncton NB
Hopefully one of the mechanics/engine builder guys will jump in to confirm.
Putting it back together is the fun part 🙂
gaz
729
Wa, Bremerton 98310
Ranger 5" (1½" Hiryder/3" body), BII 4" Procomp
Ranger 5sp, BII A4LD
Ranger 32"/4:10LS, BII 33"/3:73LS
@RussAdams
In reference to your "in for a penny, in for a pound",
Having them resurfaced, if needed is not a great expense... additionally it would be a great opportunity to let a reputable machinist do a performance valve job. While I do not know the history or use of this engine, if it has anywhere near 200k it will benefit from a solid valve job. No dought the guide are worn and the seat would benefit.
I have not checked the prices lately but I expect the head mill to be $200 and the valve job $250 not including replacement components (though valve guides and seals are very inexpensive).
RussAdams
50
Ford Ranger XLT
I'm just starting to take the valves out.
I had to torch some of the exhaust manifold bolts and want to replace the seals in case I torched em.
The first valve is out and looks in decent shape. But the guide is pretty sloppy. No sucking sound when I pop it out.
19Walt93
4,723
Canaan,NH
351
3"
235/55R16
You already have it apart, have the heads done now so you don't have to do the job over again.
TexasDuck66
July Truck of The Month
25th Anniversary Merch
