4.0 gradually getting harder to start...where to start?
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
So my ranger usually fires right up, sometimes needing a little more cranking and some throttle. Lately this has been happening more often. 20/80 hard start is now 80/20. It needs extended cranking and throttle to start 80% of the time. Where would be a good place to start looking?
PS. I already did the lower intake gasket last summer. New injectors too. IAC,DPFE,EGR etc all have been replaced at some point with motocraft parts. Newish autolite double platinum plugs. The only thing I haven't messed with is the fuel pump, pressure regulator, and 02 sensors. Mileage is 90k original miles. Yes that's right, a '93 with 90k miles. I love my ranger so much. Anyways, you guys think its fuel related?
holyford86
Some guy with a problem
610
Plattsburgh, NY
many
33x12.50R15
Check your fuel pressure
Fast Eddie
2,656
On The Road
Ranger Edge
2x4 on 4x4 Factory Chassis
Call we wonker but I found a new battery usually does the trick. Hey, that's been my experience. What else can I say?
Junk Collector
Truck of Month
4,798
Rapid City SD
Fuel filter? Made a HUGE difference on my fiance's '95 that had sat for a few years.
Think you should get a fuel pressure reading too. If it's bleeding off back into the tank, or through a ruptured regulator, or through leaking injectors, or just low pressure in general from a weak pump... a good reading at idle and again at low vacuum will give you a really good place to start.
FWIW I have had several Explorers that really required extended cranking to fire up. Their engines were used in donor projects and received new pumps, filters, and nice clean fuel tanks. The long crank time issue disappeared.
