302 swap into 05 ranger questions
BigggT
Connecitcut
3.0L V6
Hey guys i am currently building a 302 and i have a 05 ranger with a 3.0l manual RWD.I REALLY want to put my 302 in the truck but i heard the electronics are gonna be a pain. I was thinking would i be able to do the wiring from a 96-00 explorer into the truck and use the 302? I think that could work and tune the explorer ecu. obviously i would have to get all the explorer sensors and what not and play around with it a bit but i think i could make it work. My truck has the least options possible. No security and no power windows nothing.
Rock Auto 5% Discount Code: F9A1A579ACFAD1: October 1st, 2021
Mac
181
C. Wisconsin
2000
199
There are quite a few things that make it tougher to swap. Only one that has done that late a swap would be Hooiser1104, check back for his build. Biggest problem he had was dealing with the digital speedometer and a couple of other small items. Lots of other things changed 2001 and newer.
Dave
BigggT
Connecitcut
3.0L V6
That is a GREAT thread but still no write up! I have the winter to figure all this out. Sounds like finding the 96 explorer will be what i have to do. and my truck doesnt have cruise control so speedo problem solved? haha the only concern i would have is could i do a manual trans from a f150 or something or will i HAVE to do an auto trans?
Lil-Pony
5
San Antonio, TX
Take a Guess
2.8 soon to be 4bt
If you want a manual might as well get a 302 of 351 out of an f150 with the trans. It will be the same ampunt of work and the ecm is already programed for a manual. I think the year to look for is 92-96
Lil-Pony
5
San Antonio, TX
Take a Guess
2.8 soon to be 4bt
Well still have the mustang? If so get a shift boot from summit and a 14-18" shift rod and handle to match to taste?
BigggT
Connecitcut
3.0L V6
no i dont still have the mustang, but i have a lot of mustang parts. would i be able to do a mustang swap into the truck?!?! like mustang ecu and harness?
Lil-Pony
5
San Antonio, TX
Take a Guess
2.8 soon to be 4bt
Anything is possible with enough effort. I believe so. Do you still have all the supporting accessories from the mustang?
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
51
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
The mustang electronics won't support the ranger's needed functions. Stick with the 99-01 explorer 5.0 as a donor, unless you plan to drop the tank and install an older pre 00 tank with return style fuel system. The easiest route would be to pull the entire vehicle harness including the dash harness out of the donor and swap it into yours (the dash comes out with only 7 bolts). The dash to engine bay harness is where everything changed. It may not sound like the easy way, but after doing several swaps including my sport Trac and an 01 ranger, I've got over 8 hours just soldering wires in each swap, would of taken me less than half of that to just swap the harness. Use the explorer FEAD as its a smaller package than the mustang. Explorer oil pan will be needed. Explorer motor mounts should work...
SVT
Lil-Pony
5
San Antonio, TX
Take a Guess
2.8 soon to be 4bt
Thats another route but i tend to work with what i have. Leaves money for other areas :) its doable both ways. Thought mustangs were return-less tho.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
51
GT-40 5.0L EFI W/AC
The only 5.0 mustang that was returnless are the coyote mustangs (11+), but if your swapping that, you've got another can of worms...
SVT
Lil-Pony
5
San Antonio, TX
Take a Guess
2.8 soon to be 4bt
Haha nope$$$$$$
Setting up a return isnt that hard...
And a dash can always get custom gauges it also a play to so street legal is optional im guessing. Things become really simple in truth. Though as svt said alot of soldering will be needed no matter what
BigggT
Connecitcut
3.0L V6
no i do not have the mustang accessories but i need it to still be OBDII anyway because of CT laws. so im going to have to do the 96-00 explo swap. I already have the block and im modding the engine, but will i need a specific intake because i currently have the 94-95 cobra intake right now. also would i use the ranger drive shaft or the explo one? and by swapping the dash harness will everything work like the speedo and radio and lights etc...
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
51
GT-40 5.0L EFI W/AC
You will need the explorer timing cover, but you can use the cobra intake. The explorer uses the gt40 intake. Using the entire explorer harness, both the dash and underhood, will operate as normal, Speedo and all. Make sure you grab the G force transducer located on the driver side framerail under the seat area, as this is for speedometer operation. By swapping harnesses, you will gain power windows/locks, cruise, and any other option your donor has. You don't have to install the power windows & locks if you don't want them, but they are a nice luxury. When you remove the cps (cam position sensor) and cam syncronizer (replaces the dizzy), bring #1 TDC before you remove the syncronizer, pull the cps and take not which way the syncronizer is pointing, as this is crucial for proper timing. I recommend marking the syncro housing with a marker where it went. If you choose to purchase a new syncro, get the one from rock auto, its cheaper and comes with the installation tool. You also might want to get a tuner so you can pull in all the power and mpg available, as well as delete the auto tranny if you go with a manual...
SVT
BigggT
Connecitcut
3.0L V6
that is good information! THANKS! but the reason i ask is because the 94-95 cobra intake has a built in elbow unlike the explorer gt40 intake. and i have just the block right now with some afr165 heads and cobra upper and lower and 24lb injectors with a calibrated maf. so i was going to take all the sensors and covers from whatever will work on the ranger. in this case im assuming the explorer. and when you are talking about the cps and synco of the donor explo i get right? because with the 5.0 block im building i dont have the distributor in it but i can make #1 TDC and im doing all my research as if its a new build and i had nothing.
