302 remote oil filter location?
35Remmy
12
Binghamton NY
1999
2.9, 4.0
Any ideas? I dont see anything obvious. Right to the frame and behind the drivers side front tire?
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
I mounted mine behind the left side of the front bumper.
Elutheros
129
Central Texas
Mine is on the left side mounted to the sheet metal under the charcoal canister. I had hydraulic lines made at CarQuest for $90.
Ramcharger90
1,708
N/A na
306, Bcam,
insaneranger
42
Tennessee
302
225/40 R18
Mine's mounted on the drivers side on the outside of the frame using a Trans Dapt kit.
35Remmy
12
Binghamton NY
1999
2.9, 4.0
Thanks for the replies guys, giving me some good ideas! Ramcharger, im using AN fittings and braided hose on everything else, why should i skimp here right?
Insaneranger, thats the first place i came up with was on the outside of the frame rail.
35Remmy
12
Binghamton NY
1999
2.9, 4.0
Guys, which way are the hoses routed? Does it matter? The adapter i just mounted on the frame rail is stamped "IN" and "OUT".
ericbphoto
Overlander in development
16,593
Wellford, SC
6"
If it had to guess. I would put oil pump supply pressure to the outside of the filter and return from the center. Most filters are set up to catch the dirt on the outside of the media.
But wait for someone to confirm. Have you googled it?
35Remmy
12
Binghamton NY
1999
2.9, 4.0
Eric, i wasnt paying attention. The block adapter has IN and OUT arrows heh.
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
And so i just got finished mounting it there!
The tire is going to throw crap on the filter and may hit it on a full rt turn. Please be careful attaching the hoses-"out" on the filter bypass goes to "in" on the filter adapter, if they're backwards the drain back valve will stop the oil flow.
Junk Collector
Truck of Month
4,798
Rapid City SD
I mounted mine on the inside of the passenger side frame rail and tucked the hoses under the oil pan. FWIW I also used tractor hydraulic hoses... those hose barb ones are junk, they will leak. Mine are going on 10 years old now and are nice and dry.
35Remmy
12
Binghamton NY
1999
2.9, 4.0
19 Walt, i would have never known that IN goes to OUT and visa versa if i didnt READ the instructions!!
Oh, im moving it over to the left more. On full right lock the tire sits about 2" under the filter. On full suspension compression it will be a disaster. Thanks for pointing that out. Duh.
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
Don't feel dumb. Would you like to guess how I know about the drain back valve blocking the oil flow?
35Remmy
12
Binghamton NY
1999
2.9, 4.0
Yes!!! I would like you to tell me all about it actually heh..
