302 mock/setup block
svtcards
137
Lyman maine
302
3'' front 4''back
I was wondering if anyone out there ever used a plastic set up mock up 302 block for there ranger v8 swap?if so how much easier is it then pulling in an out a regular 302 short block?was contemplating getting one but can't find any under like 400.is it worth it?or just do it the regular way.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Eh, get a front frame section. Much more practical.
If you would weld casters and legs to it, end result is an engine stand and mock up jig all in one.
19Walt93
4,412
Canaan,NH
351
3"
235/55R16
I used a bare block to place the mounts for my 351,I'll bet you could find a junk 302 block to use for a lot less than $400.
svtcards
137
Lyman maine
302
3'' front 4''back
How much do those weigh.150 plus lbs?the mock up one is only 30lbs.and by the time I put headers upper lower intake it LL weigh quite a bit.i do c alot of those though
Ramcharger90
1,708
N/A na
306, Bcam,
I didn't do any of that. I put the 4.0 rubber mounts in the same holes my 2.3 mounts came out of and let the transmission help locate the engine in the bay.
My truck handles pretty good for a ranger with twin I beam and no sway bars.
svtcards
137
Lyman maine
302
3'' front 4''back
Really! U didn't have to drill any holes or anything?the 4.0 rubber mounts bolt right up to the 302 engine?what plates did u use?
17,520
SW Iowa
I paid half that for the running 302 that has been in my truck for 9 years.
19Walt93
4,412
Canaan,NH
351
3"
235/55R16
I wouldn't be surprised if you could buy a junk 302 for peanuts and strip everything off the block to make it lighter. It's still going to way more than a plastic dummy but I assume you've got a motor crane or chain fall to lower your engine in place that would work to lower the block in there.You're in Maine, you should know that it causes New England Yankees pain to waste money.
Ramcharger90
1,708
N/A na
306, Bcam,
Ricks rangers adapter plates on ebay and 4.0 rubber mounts from rock auto. Cut the alignment dowel off the top side of rubber mounts
svtcards
137
Lyman maine
302
3'' front 4''back
svtcards
137
Lyman maine
302
3'' front 4''back
Exactly!we LL make anything work.lmao
svtcards
137
Lyman maine
302
3'' front 4''back
Y did u go with those motor mount and plate setup when most people on here say to use advanced adapters mounts or convertible foxbody 5.0 mounts?
svtcards
137
Lyman maine
302
3'' front 4''back
I plan on trying the sn95 mounts.i was told there the exact same as the foxbody 5.0 very mounts.which sn95 is my donor car.we LL c how those work.i was told they make engine sit a tad higher that your regular plate rubber mounts do.but not sure how much more to make a difference
17,520
SW Iowa
I bet u did!i thought that price was pretty crazy
He had it listed as an '84 with no pics which is kinda meh, for the '87 roller I knew it to be as soon as I saw the intake and a few numbers I was all over it.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
If you spend the money on a mock block, you can probably recoup your money trading it back and forth with other people....
Kirby N.
March Truck of The Month
