302 engine help
taco
Hello all, I have an 85 ranger with what I believe to be an 83 mustang 302 in it. Ever since I bought the truck (after the swap was done) it has been a disaster, when I was just looking for a small project. The last time I started it, about 4 months ago, I had to turn the idle WAY up just to get the engine to fire, and now it is firing up and just dieing right away. after I adjusted the idle a few times it wouldn't even turn over. I was wondering for a possible solution to this. I have checked and it is not a vacuum leak. It also went through about a gallon and a half of gas in about 30 seconds with just the fuel pump running and no leaks in the fuel line. any help would be appreciated, thanks.
5,374
I assume a carburetor on '83?
'84 Mustang was first year of optional fuel injection, I think
And for spark you are using.........??
Distributor with TFI, HEI, Duraspark?
Reads like float's valve is stuck open(or not adjusted) and gas is overflowing into the intake.
"It also went through about a gallon and a half of gas in about 30 seconds with just the fuel pump running"
If you have an electric fuel pump it should not run when engine is not running, if you do have a carb then you could fill a cylinder with gas and hydro-lock the engine, bending or breaking piston and rod.
That's the reason to use mechanical fuel pump or run electric fuel pump power thru Oil Pressure switch relay, so no power unless there is oil pressure(engine running)
