If you can find a mid-late 70's 3/4 ton D44, you can swap the brake caliper bracket directly onto an F150 knuckle. Actually you can swap any of it, the bolt pattern for the 3/4 ton spindle is exactly the same.
The issue you will run into is that since the 3/4 ton rotor is much larger, you won't be able to use your 1/2 ton rotor. This is solved by using your 1/2 ton spindle and a late model Dodge front brake rotor. A buddy of mine did this exact setup on a Jeep. There was some minor machine work that had to be done to the rotor I believe, but otherwise it is a bitchin setup and you gain dual piston calipers with the 3/4 ton stuff.
One other thing of note is that you CANNOT put 1/2 ton brakes on a 3/4 ton knuckle without doing major reconstructive surgery to the knuckle. The caliper won't even come close to fitting. Just FYI, I had a set of flat top knuckles from a 3/4 ton D44 that I considered using but it's way too much work for a modified knuckle that is potentially dangerous.
I know plenty of people running mil tires on standard 16.5 rims and have had no issue at around 20 psi with no beadlocks or screws.
Sent from my C771 using Tapatalk 2
I know a few people too, the problem is that military tires are very stiff and the rubber compound is very hard. Really bad choice for offroad tires. Better to go with a different tire if you REALLY want 16.5's, OR just do it once and do it RIGHT and get 17" wheels.
