3.0 vulcan MLS head gaskets?
Aaron Powell
6
Arizona
Mazda B3000
I'm getting ready to pull the heads in my 94 3.0 vulcan and replace an exhaust valve and lap all the others. From what I can see, it has MLS head gaskets, but I can't find them for this year. Will they work off of another year 3.0? I understand MLS is more for aluminum to cast and aluminum to aluminum, but I'd prefer MLS if I can get them.
Aaron Powell
6
Arizona
Mazda B3000
I guess no one knows. I've been trying to compare them online, but to no avail am I finding one that seems to be a match. Google searches aren't turning anything up
NIGERIAN RANGER
28
Lagos, Nigeria
Why not use the composite gasket types? Over here, if an engine has overheated severely, we don't use the MLG ones, but the composite type. This are my opinions though.
Aaron Powell
6
Arizona
Mazda B3000
It's just a preference of mine if I have the option
Guanfy
91
Crawfordville, Florida
Mazda B3000
Stock
Stock
15in
I haven't seen any floating around for the '94 3.0. My two cents would be to go composite with a nice set of Felpro. Without going down the rabbit hole composite gaskets are more tolerant of roughness so are more forgiving in sealing against a not mirror smooth surface. MLS are superior in sealing IF they are setup properly. They require very smooth mating surfaces. If you know all this and plan for it best of luck to you. I fixed some Subaru boxer motors of their head gasket issues doing exactly what you are trying to do now.
NIGERIAN RANGER
28
Lagos, Nigeria
You're right with the composite suggestions too, but I hope the OP would even accept it, since he's still insisting on MLS type.
Hopefully, he'd get the one of his preferences.
Aaron Powell
6
Arizona
Mazda B3000
I've just decided to settle for the
Composite head gaskets
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
WHAT!?! WHY!?!
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
That makes me a sad panda...
8,370
No need to use MLS(multi-layer-steel) head gasket on the 3.0l Vulcan, use composite gaskets
When car makers, or racers, started using aluminum heads on cast iron blocks the head gasket would fail after 20k-50k miles, even faster on racing engines with high ratios
Problem was the expansion rate of cast iron vs aluminum
Aluminum expands faster and 5 to 7 times more when heated than cast iron
So each time an engine was warmed up the composite head gasket was RUBBED as the aluminum expanded faster
So after enough drive cycles, warm up/cool down, the head gasket would rub thru and fail
MLS was used so aluminum head could SLIDE on the head gasket as it expanded, instead of RUB
But there was a problem with straight MLS gaskets, cooling system could leak in colder climates as aluminum shrunk down even more, lol, so not uncommon to have a COLD coolant leak between head and block
So MLS now has a bit of composite material
3.0l has cast iron head and block so use composite
MLS is not a "better" gasket, its a specific use gasket
If you have aluminum heads then use MLS regardless if block is cast iron or aluminum, because the head still expands faster and more than the block
