3.0 The fun begins
Biggfoot44
42
USA
Ranger 2wd
Just to make sure I'm following :
The engine driven fan already removed, replaced by 12V fan before baseline 0-60 times ? Only change one pully, and 4% faster 0-60 ?
I'm sure OP has mentioned elsewhere , but could you remind us auto or manual, which gear ratio ?
88workcar
48
Pierre Part La.
Ranger XL
No baseline before fan, sorry. Manual, I'm sure my driving of "this truck" is improving also. I made three hard runs prior to the pulley 10.41. After, my 1st run I was holding a coffee and ran a 10.32 I poured coffee all over lol then threw it out and made three good pulls with a 10.02 a 10.teen and another 10.0? Most definitely faster with the pulley and my gas gauge is not moving as fast as before.
I did have one issue with the truck getting warmer that normal, sitting in Fast food line, 5 cars back, AC on and it's mid 90s here. I turned off the AC and revved the motor a little while creeping up. It settled down right away. I want to swap the radiator for a 4.0 model and drop the thermostat to a lesser degree but not by much. I may even replace the fan clutch and reinstall it and do a accurate test. That is a debated subject lol.
8thTon
--- Banned ---
806
Pennsylvania
My world is filled with stuff that needs to be fixed
If the temp was rising at idle you can be sure the thermostat was already open fully but there was not enough circulation of air and/or coolant. I lower temp thermostat would not be open any further, so would not have made a difference.
88workcar
48
Pierre Part La.
Ranger XL
Correct, and thanks for the catch. Maybe the larger capacity radiator will overcome the slow flow.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Bmw 5 series come with a 12v auxiliary coolant pump. They're the same.size as the plumbing for a Ranger heater core. Just a thought. Boneyard has them cheap.
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
645
Central Indiana
Glad to see it's going well so far and you're happy with some tangible results!
The 97-02 Explorers with the 5.0 had a radiator that was a drop in replacement for the 3.0 rad, but twice the thickness FYI. My cooling fan rarely comes on unless I'm beating on it.
Ranger 3.0 Rad:
Explorer 5.0 Rad:
Bgunner
1,083
Western Mass.
Ford/Ranger XLT
225/70/R15
@88workcar, Did you ever give us your rear end gear ratio?
88workcar
48
Pierre Part La.
Ranger XL
Got my intake in to start porting it and BOOM it's cracked. So now I wait again.
88workcar
48
Pierre Part La.
Ranger XL
The seller refunded me on the intake, turns out it was wrong so the crack was a blessing. I did overheat again at idle with AC on. I pulled the front off the truck and washed all the bugs and rocks out of the AC coil and radiator. I also installed a 180* stat. I have not had another issue not even close.
