BoArDwAxStYlE
- Jan 14, 2013
- Reaction score
- 0
- Make / Model
- Ford
- Automatic
First off hello everyone.
I'm having a little bit of a problem and looking for some help.
I recently had my CEL come on and the codes were
Lean bank 1, Lean bank 2, Misfire 3, Misfire 5.
I changed the plugs to motor-craft, and gaped them to .046
Cleared the codes to see if they were the problem.
The only problem code i am now getting is cyl 5 misfire.
Ive cleared it only a few times between about 50 miles.
Other know issues.
- I believe the head gasket is going, if not partially gone on pass side.
- The temp controller valve for heater core start to weep a steady stream.
I replaced it then 2 days later it popped again.
- I checked the plug wire against a spare and its not getting any spark at all even from coil. The coil was replaced last year in Nov.
Also i'm getting a serious loss in power and fuel economy.
Poss cam position sensor / Cam synchronizer / just head gaskets?
Any and all help thanks.
Other know issues.
