3.0 engine problems.
BoArDwAxStYlE
First off hello everyone.
I'm having a little bit of a problem and looking for some help.
I recently had my CEL come on and the codes were
Lean bank 1, Lean bank 2, Misfire 3, Misfire 5.
I changed the plugs to motor-craft, and gaped them to .046
Cleared the codes to see if they were the problem.
The only problem code i am now getting is cyl 5 misfire.
Ive cleared it only a few times between about 50 miles.
Other know issues.
- I believe the head gasket is going, if not partially gone on pass side.
- The temp controller valve for heater core start to weep a steady stream.
I replaced it then 2 days later it popped again.
- I checked the plug wire against a spare and its not getting any spark at all even from coil. The coil was replaced last year in Nov.
Also i'm getting a serious loss in power and fuel economy.
Poss cam position sensor / Cam synchronizer / just head gaskets?
Any and all help thanks.
Rock Auto 5% Discount Code: BD8D9A3814E19D Expires July 5th, 2022
James86
6
55381, Minnesota
2012,
Ford,
Ford,
3.0 Flex Fuel, 2.5L, 3.3 Flex Fuel
WHY DO I KEEP BUYING DODGES?!?!?
If it's misfiring and one cylinder is not getting spark, it sound's like you may have solved your mystery. The cam syncro sensor is just a vane that rotates to indicate when to send a signal to the computer. Unless someone else chimes in, I'd suggest it's the coil pack. Did you put in a new one or a junkyard coil pack? When I had an injector die (essentially running on 5 cylinders like you) it was horribly gutless and sounded like shit.
5,148
For the head gasket, remove rad cap with engine cold, start engine, no coolant should come out, there is no pressure in a cold cooling system, if coolant comes out or you see bubbles consistently then you may have a head gasket issue.
If not I would change rad cap, your current cap may be allowing to much pressure to build up in the system causing the heater valve to leak.
No spark on #5 could be the coil again, "new" now means "never tested" not "it works", lol, it didn't used to be this way but more and more I am finding this to be true.
But cam position sensor tells the PCM when to spark so that could be the problem.
Have a read here:
http://www.therangerstation.com/tech_library/camshaft_position_sensor.html
BoArDwAxStYlE
Yeah i bought the accel super coil-pack.
Yeah it runs real shitty when its on just five. like its running on 4.5 actually. really shaky.
I will try the raid cap idea. Thanks
James86
6
55381, Minnesota
2012,
Ford,
Ford,
Did you replace the coil pack for a particular reason? Like this cylinder had been misfiring before? Is the accel pack a "performance" pack you put on for kicks and the old one still worked? Maybe you altered the side-effects of a different issue and caused another...
BoArDwAxStYlE
I had almost this exact problem last year in first week of nov. The accel is a performace pack. That up until recently has worked fantastically. The old one drop cyl 3 and 5 on factory pack.
I also just passed 100k miles.
James86
6
55381, Minnesota
2012,
Ford,
Ford,
Is it possible something is frying your coil packs? I didn't think they got much power suplied to them, just a signal and the coilpack itself is what creates the currrent needed for a spark, but I don't profess to know much about coilpacks.
