B2_driver
- Jan 27, 2010
- Reaction score
- 0
- Location
- Crawfordsville, IN
1990
199
- Make / Model
- Ford
- Engine Size
- some v6, some v8, 3.9 cummins
- Manual
- My credo
- do unto others as they do unto you
ive got a 93 ranger with a 3.0. it will start up easy but then starts to miss out. ive replaced the distributor with a good used one, cap/ rotor, wires and plugs with no change. all 6 injectors good used, nothing. the head and intake gaskets are new so no vac leaks. good known ground to the block. brand new pump and filter for fuel. 38 psi fuel. checked MASS AIR meter, IAC, coolant temp, o2 sensors, IAT sensor, all tested and OHMed good. rechecked timing. i dont know where else to go with this thing. any advice would be greatly appreciated and thanks in advance.
