3.0 barely runs
B2_driver
Crawfordsville, IN
1990
199
some v6, some v8, 3.9 cummins
do unto others as they do unto you
ive got a 93 ranger with a 3.0. it will start up easy but then starts to miss out. ive replaced the distributor with a good used one, cap/ rotor, wires and plugs with no change. all 6 injectors good used, nothing. the head and intake gaskets are new so no vac leaks. good known ground to the block. brand new pump and filter for fuel. 38 psi fuel. checked MASS AIR meter, IAC, coolant temp, o2 sensors, IAT sensor, all tested and OHMed good. rechecked timing. i dont know where else to go with this thing. any advice would be greatly appreciated and thanks in advance.
Rock Auto 5% Discount Code: BD8D9A3814E19D Expires July 5th, 2022
4,966
From what you have checked I would say computer is at fault
Pull it out and open the top
Should look like this: http://www.auto-diagnostics.info/ford_eec_iv
You can see the 3 Blue capacitors in the picture, they can leak and it will corrode the circuit board and cause any number of problems.
You can replace them and clean up the circuit board, or find similar year 3.0l replacement computer, computer must match transmission, i.e. manual or automatic, and EGR or no EGR
B2_driver
Crawfordsville, IN
1990
199
that was my last place i was thinking of trying. its really all thats left now. thanks for the input
