3.0 5spd auto engine swaps
EthanBuck
Utah
I’m sure that my 3.0 is going out soon and though i’m sure i could find one and throw one in for cheaper then i could swapping in something i’m dumb and would like to toy around with the idea anyway. Though i’m a fan of the ol’ 5.0 it’s also fun to look around at other options
Looking at the trans which i think is the 5r55e and i could be wrong would the AJ30 be a option for it at all or is the 5r55n completely different?
I couldn’t quite find if anyone’s tried it yet..
franklin2
1,758
Virginia
AJ30? A jaguar engine?
EthanBuck
Utah
Yea i was looking into it and it uses both in the S-type jag and ford thunderbird it’s attached to the 5r55n and looking at the bell pattern on the 5r55e doesn’t look too far off from the pattern on the AJ30.
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
If you have that much cash to spend buy a crate 302 and have it chromed. By the time you adapt that thing into the truck, buy the electronics to run it and get it running, the 302 would seem cheap and easy to do. How about an EcoBoost 2.3 from a Mustang or Ranger if you don't want a 302? Being a 2002 with OBD II does your state require emissions inspections? NH and many others use the Gordon Darby system for testing(96 and newer in NH) and the VIN in the PCM has to match the VIN on the registration. Please do some research before spending a bunch of money.
EthanBuck
Utah
Mainly most of this is a what if situation and the 302 conversion is pretty common around where i live and i might in the end doing it. I had a 95 mustang 5.0 with 4.11 gears and i’m just not a fan of the mpg so i was mostly looking into the 2.3 eco when i saw that the trans in the same in the thunderbird and jag. It also tends to get a slight higher mpg with lower displacement and higher hp then the 302 though who knows in reality what’s reported i was lucky getting 16 in the mustang. Though it is mostly a novel idea than something that’ll ever be reality, And around here we do do emissions but with how common 302 swaps are around here it doesn’t seem like they’re as strict about having matching vins but i’ll ask a friend. Also looking at chromed crate engines they’re about a the same price if i just went ahead and bought the jaguar itself and took what i needed let alone going to a junk yard..
8,370
AJ30 engine shows its 27.5" wide so won't fit in Ranger engine bay
302/5.0l V8 is 19" wide and barely fits
Anytime you get into Overhead Cams in "V" engines the width starts to be an issue, 4.0l SOHC barely fits
DOHC V6 or V8 are minimum 25" wide and just don't fit
You can of course delete heater/AC and move the steering shaft, and have exhaust exit outside the frame rails, definitely a Custom Build
superj
2,577
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
Why notbuse 3.73 on he 5.0 swap instead of 4.1? That definitely has to be eating some gas with that gear set up
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
I was being facetious about a chrome engine, my point was how much cheaper a 302 would be than a Jag. Most people looking for gas mileage wouldn't run 4.10 gears. My Mustang has a modified, carbureted 302 with a conservative cam, a T5, and 3.55 gears, and it runs 13.8 @ 102 in the quarter. One Saturday I gassed up, drove 2 hours at 75-80, made 9 passes down the track, drove back home, then drove to work and back until Wednesday when I filled up again. 19mpg. If you're getting 16 mpg with a 95 Mustang - even with 4.10/4.11 gears- something is wrong.
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
646
Central Indiana
The Vulcan 3.0 has a unique bell housing bolt pattern. A 3.0 trans isn't going to bolt to anything but a Vulcan 3.0.
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
At this point, a Honda K swap would probably be easier than the Jag set up.
Here's a K swapped Chevy
and a K swapped Fox Body
It's the "new LS swap" lol
superj
2,577
ranger edge
none
none
235s
