Katalyst
- Mar 2, 2011
- 0
- Age
- 32
- MN
- Ford
- Engine Size
- 2.9 Litre
Well that title should attract enough attention
Ok so here is my situation, I have a 1990 2wd Ranger with the 2.9l. As of yesterday my Mitsubishi fm132 tranny locked up on me, now I need my truck back pretty fast, and I should probably just order a reman'd Mazda r1, but that will take too long. So I found a truck at the local yard, its got a 3.0 in it, with the tag on the tranny saying F57a da. As far as I can tell, that's the M5R1, the Mazda one. Now I know that if this truck was 2wd it would be a direct replacement (thank you extensive tech library). My problem is that its 4wd. If I pulled this transmission, could i find a tail housing for it and just pull the t-case off and put the tail housing on? I know there are issues with the output shafts being different lengths, so I guess I'm asking if this will work or if I should just pull the tranny, t-case, and drive shaft from the truck in the yard and swap them all in with the t-case just acting as a dummy? Or if that idea is dumb too. You guys all have more experience then me so any advise or suggestions would be greatly appreciated.
P.S. The mitsu fm132 is a crappy tranny, thats why I would rather have the Mazda, and none of the yards have 2wd rangers in them.
