ndccpf1
- Aug 26, 2009
- 1
- New Jersey USA
- Mazda
- Engine Size
- 4.0
Heat was on FULL all the time and TEMP dial had no effect.
I had already done years back the blend door repair kit (metal pivot) and then in 2014 the blend door server motor
So now I dropped the glove box and put my right hand on the servo motor as I turned the TEMP dial... felt NO MOTION
Next I did a voltage and resistance check on the servo plug and I did have 12V and with truck off.. I had the pins for varying resistance when turning the TEMP dial..
SO that confirmed BAD SERVO... which only lasted exactly 5 years (almost to the exact date !)
Ordered from Ford dealer (good price) and replaced.
Helpful tip since I had replaced the blend door with the repair kit I had to cut a hole in the bottom of the heat chamber under glove box
When you remove the OLD servo the blend door will move internally so lining up the NEW servo will be very tricky...
SO... I reach in under the hole.. and held the blend door in the HOT position which is in the direction of the transmission tunnel then plug NEW servo in and turn truck to ON and turn heater TEMP dial ALL the way to HEAT.. this will turn the keyed shaft to mate to the NEW servo which is to place in position and lower straight down not on an angle...
All good again.. NEW servo made in MEXICO (just FYI)
