289 Rods in a 2.9L?
4
Alberta
I was curious if anyone has tried to run 289 rods in a 2.9 before? the dimensions are pretty close with the 289 rods being 0.01" longer.
fastpakr
2,832
Roanoke, VA
Do all the other measurements line up, like bore diameters?
4
Alberta
Looks like the wrist pins on the 2.9L are 0.033" larger and the Rod Journals are 0.003" larger on the 2.9L. So it would be a little bit of machining to each rod, but it might be possible
rusty ol ranger
2.9 Mafia-Don
7,491
Michigan
177 CID
The only reason I can see, since the length difference is insignificant, is if he is rebuilding a 2.9 and already has a set of 289 rods laying around.
fastpakr
2,832
Roanoke, VA
Probably lots more options for aftermarket 289 rods too.
4
Alberta
Mostly because I like to burn my money on pointless upgrades. The same reason i'm doing a $1000 brake upgrade on my Nissan that's only worth $1500 lol
