25+mpg 4.0l ohv build
gaz
649
Wa, Bremerton 98310
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
Naddanme:
I urge you to consider
replacing your timing set verses waiting for it to go. Additional prudent moves for an OHV 4.0 with 140k, a new oil pump, water pump and inspect those push rods and rockers; the first 2 (3) items will ensure a solid dependable power plant, inspecting and taking the appropriate action with the valve train will ensure the best possible performance ..)
HOORAA Ranger driver!!
Naddanme
90
Pennsylvania
Timing been taken care of. Hadn’t really thought about replacing the other stuff if it isn’t giving me any problems. But it’s not a bad idea. Thanks
gaz
649
Wa, Bremerton 98310
Will a 2.9 steering pump work with the 4.0 OHV in my BII?
gaz
649
Wa, Bremerton 98310
Today I have the new set my Mahle 2001, SOHC pistons for my 1994 OHV 4.0L. They weigh within 1.4g from lightest to heaviest; I can now balance this bottom end to within 0.10g rotational and reciprocating weight. This is a 10% performancein gain in fuel economy, hp and tq...FOREVER!
Really, really makes me wonder why this isn't done on EVERY NEW autombile, from the factory; clearly they NEED us to use ten percent more fuel...FOREVER??? 🧐🧐🧐
A note of IRONY, in auto racing where fuel economy is most probably the least concern, EVERY ENGINE HAS THIS PROCEEDURE PERFORMED!!!!!!!!!!!!!!! I wonder why, don't you?
Blmpkn
Toilet enthusiast
6,358
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
I'd probably say thank manufacturer stockholders for the lack of a balancing that in-depth. Such things would cut far too deep into profit margins. 2 extra mpg be damned.
My 2 cents though.. The level of balancing we get from production motors is really more than sufficient honestly. Race motors get balanced to such a degree because they're just that.. Race motors.
Think about the average rpm of a motor over it's lifespan.. A race motor will live its entire life at 6k.. Minimum. It needs the anal-retentive balancing for longevity. As you said, racers don't give a.f how many mpgs they get. All we care about is power... and how many races/passes we can get from a motor before 8k rpm shakes it apart.
The average motor though, probably lives 99% of it's life between 2500-3000 rpm, where even the crummiest of factory balances is usually good enough to last over 200k miles.
I'm really rooting for this build. Youve clearly put a metric s-ton of thought into it, I hope you achieve the results your after.
  • Like
Reactions: gaz
gaz
649
Wa, Bremerton 98310
Which year SOHC oil pans can be used with the OHV to benefit from the built in girdle?
DPDISXR4Ti
33
New York
Bump, bump.... How's this project going?
  • Like
Reactions: gaz
gaz
649
Wa, Bremerton 98310
DPDISXR4Ti,
Hello,
My needs to drive the Bronco changed, so to drive it now, I bought a complete running 94 Explorer to get the computer, wire harness and accessories I was missing for the swap.
The actual engine I'm building is going to take me another 4-5 months due to my budget. If this engine isn't ready by the end of August, I will stop everything else and finish it as I want 2-3 months of solid use on paper to feel comfortable for winter reliability.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Hard core.
Mega squirt is the key.
gaz
649
Wa, Bremerton 98310
Bobbywalter,
If The "Mega-Squirt" system is capable of improving the fuel efficientcy +05.0% or more in the BII with my built 4.0l, then I will consider it.
lil_Blue_Ford
6,054
Butler, PA, USSA
4.9L
That I‘m not sure of, but have you considered doing an electric power steering pump? @PetroleumJunkie412 did one in his Ranger and I’m working on repeating the process.
lil_Blue_Ford
6,054
Butler, PA, USSA
4.9L
Bobbywalter,
If The "Mega-Squirt" systemiis capable of improving the fuel efficientcy +05.0% or more in the BII with my built 4.0l, then I will consider it.
Maybe talk with @PetroleumJunkie412 , he’s running megasquirt
Blmpkn
Toilet enthusiast
6,358
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
There's no way megasquirt wouldn't increase efficiency.. mabey not 5%.. but still.
gaz
649
Wa, Bremerton 98310
I have learned that the 2 systems have equal output and only slight differences in the output to the hoses, the hoses are the key; so using the hose for the gearbox is best, the pumps can be interchanged with only slight output angle differences. In a pinch, a 2.9 hose could be used for a 4.0 and vice versa...in a pinch.
gaz
649
Wa, Bremerton 98310
5% of 30mpg is 1.5mpg, a 1½ mpg increase appeals to me but 10% would be a done deal!
Reading through the megasquirt web page, history and product information reminds of being given 2 sticks instead of a spoon, to eat a bowl of soup. While at first I was bewildered and lost, I grew to appreciate the simple genius and efficiently of the 2 sticks and they are now my go-to soup utensils???
Doing the math, a 5% increase in fuel economy would save me $172/year @$4/gl; I expect to drive 10k mi/year, so it would take 6 years to pay for itself if I can install and set up a Megasquirt system for $1,000 or less. By ten years, not accounting for fuel cost increases I would pocket $537, while a 10% would pay for itself twice as fast (3years) and the savings at the 10 year point would be, arguably, more than doubled 👀
