James Fremont
- Jan 27, 2021
- 2
- Pacific
- Ford Ranger XL
- Engine Type
- 2.3 EcoBoost
- 2WD / 4WD
- 2WD
- Tire Size
- 225/70R16
Hi all,
This is actually more like a question for me...
A couple of days ago I was trying to refuel my truck (2020 Ranger XL) with a portable gas tank (the Fire Engine red Jerry gas can from Harbor Freight). This was the first refuel attempt outside of a gas station.
I struggled a long time and just couldn’t insert the nozzle into the refuel port deep enough to start a proper fueling as there is a locking mechanism at the base of the Jerry can nozzle that needs to engage (by seating and pressing against the refuel port mouth) to allow for fuel flow. When that failed, alternatively I then tried to use a plain old funnel with a pig-tail tube. That too, failed at the same problem – I was not able to insert the tube much beyond the fuel tank filler valve, maybe half an inch only.
The Owner’s Manual has a rather detail description and illustrations about the refueling system but I don’t see it mentioning anything about “adverse effects of inserting any objects other than fuel pump nozzles”, so I thought refueling from a portable fuel can should be doable. I tried to see what could be blocking the Jerry can nozzle entry by poking my finger into the port. Behind the filler valve (which is in plain sight as it is in place of a filler cap) I felt a flap blocking the passage. In normal fuel pump refueling the pump nozzle can be fully inserted rather smoothly so I assume this flap maybe spring loaded and will give when pushed. However, it would not budge by my finger’s pushing. I wonder whether there is some kind of interlocking mechanism behind the filler valve that prevents "unintended objects" from tempering or entering the refuel pipe. But as far as I could tell, a Jerry can nozzle is almost identical in shape and size to a pump nozzle.
Has anyone have the same experience? It is hard to believe that the refueling system is designed in a way so to deny refueling outside of a gas station. Admittedly, I haven’t really push the (Jerry can) nozzle hard to force its way in, fearing such an act might damage the system somewhere, but I thought I really shouldn’t have to if I do it right. This is my first encounter of such refueling system – a filler port without a cap - I think it would be wise of me to assume I did it wrong, but then, what would be the right way since I had no trouble doing the same thing with other vehicles ?
Any idea? Thanks!
Any idea? Thanks!
