2011 SOHC Ping/spark knock on 87
Uncle Gump
Forum Moderator
5,406
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Lead, Follow or get out of my way
We’re going to make fun of you no matter what, admitting to your mistake will just make our job easier.
I say we just start making stuff up...
Rock Auto 5% Discount Code: F9A1A579ACFAD1: October 1st, 2021
PetroleumJunkie412
2.9 Mafia
4,935
Dirtman's Basement
2.9l Trinity
Preface: I hate you all, except @alwaysFlOoReD and @adsm08. You two are cool. 😬
So, turns out the MAF on my 2011 is crazy sensitive to literally anything, even air filter varieties.
After finding out that the AFE cone filter intake I picked up on fleabay was the wrong MAF housing size, I went to the junkyard and picked up another air box cover to hack into a homebrew cone air filter tube:
Stock MAF housing with an AFE filter and velocity stack. Thought it would work fine.
Nope. Ping and knock city.
So, I put the stock air filter box back in with a K & N drop in filter. Reset the PCM, and right back to pinging as soon as the computer set its fuel trims.
Put a paper filter back in it, and now 500 miles without knock or ping.
Oh well. I tried.
This does make me nervous as all hell to put the blower kit on it, though. I... don't think I'm going to now.
snoranger
Forum Stuff Member
Forum Moderator
ASE Certified Tech
6,561
Jackson, NJ
'79,'94,'02,'20
All Fords
Oh well. I tried.
So you tried to modify something and it didn’t work out... I’ll wait for something better to make fun of you about.
PetroleumJunkie412
2.9 Mafia
4,935
Dirtman's Basement
2.9l Trinity
It really surprised me that the stoopid filter was the cause. Makes absolutely no sense to me.
I dont see how something as simple as the K & N drop in would cause so much headache. But, it does.
3,954
So we are assuming the Air Weight the MAF sensor was reporting was lower than actual air weight, so Lean mix until Closed loop and O2 feedback
But you should have gotten Lean Codes on both banks within a minute or 2 of Closed Loop
MAF only samples 10-15% of the incoming air weight so small difference changes to an upto 10 times difference at the PCM
The ACT/IAT air temp sensor is in with the MAF sensor on a 2011, but it shouldn't effect mix enough to get that lean
You are right it doesn't make sense for an air filter to cause that
PetroleumJunkie412
2.9 Mafia
4,935
Dirtman's Basement
2.9l Trinity
I'm wondering if I still have an issue somewhere, and the air filter change is just masking it.
I really, really miss my 2.9...
snoranger
Forum Stuff Member
Forum Moderator
ASE Certified Tech
6,561
Jackson, NJ
'79,'94,'02,'20
All Fords
Pull 2 spark plug wires and drill a hole in your radiator... you can pretend it’s a 2.9l
09fx4guy
130
USA
Pre Key w/ #1 Bars
265/70R16
That is really nothing to make fun of.
Its odd you had that problem. I had a K&N drop in for about 2 years without any issues. Then I switched to a K&N intake kit, and at least 8 years, no issues.
Roert42
1,161
Kintersville, PA
Ranger XLT
4.0 SOHC
Yeah, I am of the opinion you have something else going on and the filter just brought it to the surface.
sgtsandman
Aircraft Fuel Tank Diver
Forum Moderator
4,223
Aliquippa, PA
Ford Ranger XLT
4.0 SOHC
Pre-2008 lift
31X10.5R15
Boy, you have a knack for picking vehicles there buddy...
