2011 Fuel Tank pressure Sensor location
Dmichels
NJ
2011 Ranger 4.0 liter
I am have 2 codes P0452 and P0454. I need to know the location of the FTP sensor so I can check the wiring. The voltage of the sensor is all over the place on my scan tool so I am thinking bad wires. Anybody have any experience with chasing this problem down
Thanks Dave
Rock Auto 5% Discount Code: BD8D9A3814E19D Expires July 5th, 2022
franklin2
647
Virginia
I have never messed with this before, but I am getting hints that it's part of the sending unit on the tank from this picture. I will attach the picture and the key to the numerical descriptions is below.
19002Fuel tank
29057Rear fuel tank support strap
3W506435Fuel tank support strap bolt (2 required)
49A147Fuel tank skid plate (if equipped)
5W520112Fuel tank skid plate nuts (if equipped) (4 required)
69054Front fuel tank support strap
7Rear fuel tank vapor tube and Fuel Tank Pressure (FTP) sensor assembly-to-fuel pump quick connect coupling (part of 9G291)
8Fuel tank filler pipe hose-to-fuel tank clamp (part of 9034)
9Fuel tank filler pipe (part of 9034)
10Fuel supply tube-to-Fuel Pump (FP) quick connect coupling (part of 9G291)
11Fuel tank filler pipe vapor tube-to- FP quick connect coupling (part of 9034)
12Fuel return tube-to- FP quick connect coupling (part of 9G291)
13FP electrical connector
14Rear fuel tank vapor tube and FTP sensor assembly-to-fuel tank vent valve quick connect coupling (part of 9G291)
Dmichels
NJ
Thanks for the diagram I think the sensor is in line on line #7 just trying to figure out where to look for it
