- Aug 17, 2007
- 975
- central ohio
- ford
- Engine Type
- 2.3 (4 Cylinder)
- Engine Size
- 2.3/140-4
- 2WD / 4WD
- 2WD
- Tire Size
- 225/70/15-winter. 235/75/15-summer
- My credo
- built, not bought
Got this the week before thanksgiving last year, my g/f has always wanted a suv, we both wanted a 3rd vehicle on hand as a backup plan since we work different shifts. After test driving a ratty ‘01 and later trying to fix a ‘03 that was going to be more trouble than it was worth I found a “not too bad” 2011 V6 AWD auto. Ive done almost all my accessories already, had to modify the tube step mounting brackets because they were too high and not useable as actual steps. I also put on a receiver hitch and a grille guard. the tube steps and grille guard are both “aries” brand name, I don’t recommend them, the hitch is a draw-tite, I still have window vent-visors to put on, its just not warm enough yet and Im not sure if the adhesive tape will work right with the cold temperatures. I also need to put the trailer tow wire harness in. For some reason its not like the normal plug n play, theres a wire that needs to run from the converter box up to the battery. I didnt like the spare under the butt so I moved it to the inside and built a easily removeable shelf.
I do love the way it drives, need to hook up a trailer and see how it does. heres a few pictures.
