2011 4.0 in 86 ranger?
shanestarbuck68
I have an opportunity to buy really cheap a 2011 ford Ranger sport ext cab that has been rolled but only has 10000 miles on it. It is a complete truck and still drives although the entire body is trashed. It has a 4.0L v-6 and automatic transmission. Can I put that drive train into my 1986 ford ranger ext cab it also has a v-6 and automatic transmission although both these are bad.
nb11
10
South Georgia
2.3l
In short, yes. It'll be a lot of work, though, since you'll pretty much need complete new wiring to get your dash to work. I believe back in '86 engines were OBDI, while the new truck will be OBDII. Also, you'll have to have the PATS disabled by a dealer.
holyford86
Some guy with a problem
605
Plattsburgh, NY
many
33x12.50R15
people have done the swap and used the eec-iv computer from early 90s 4.0 trucks, you could get your engine to run fine with it but it won't play nice with your transmision
03ranger30
5
Mount Airy, MD
3.0L V6
Just ditch the auto and get a stick
17,768
SW Iowa
Body swap?
Then you have an old truck that literally drives like a new one :icon_thumby:
shanestarbuck68
Body swap?
So to me this actually seems like the best option if the body will fit without too many modifications
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
Take the dash with it. Then you wouldn't have to worry bout rewiring anything
17,768
SW Iowa
I don't know how it is set up under there but make sure to leave the '86's VIN in the cab.
Somebody might smell a rat if you have an '86 body with an '11 VIN (that is probably junked to boot)
It may work. I think there have been some fitment issues between the older engine c-member and the deep 4.0 SOHC oil pan.
Either way, you will need to take the trans, dash, and PATS components. It could work, but it will be a LOT of work.
holyford86
605
Plattsburgh, NY
many
33x12.50R15
There are fitment issues, you have to remove a good portion of the crossmember on the passenger side and cut a little notch in the frame if you use the newer manifolds with the wider bolt spacing
Rose2300
7
ID
Toyota
3.4
Why go through the work in putting a newer body on an old frame when you could just buy a newer (like 96+) ranger with a trashed engine for cheap and put the '11 engine in that?
Gotta_gofast
33
Wisconsin
6.0L Powerstroke
No, it was advised to put the old body on the new frame. He already has a truck in good condition, I think it would be pretty cool to have 2011 frame/power/suspension under an old school body.
Beef52751
13
Eastern Iowa
2.9
he was putting the old body ona new frame so it would look like his first gen but mechanically be a 2011
damn, i type to slow!!!
Rose2300
7
ID
Toyota
3.4
ohhhhhh....
ok that would be badass haha
colby450xc
Kansas City Missouri
Either way a lot of work and probably some fabrication involved. Swapping a dash board is a big enough bitch much less putting an updated dash in an old school truck.... just depends how much time, and how many tools you have.
