2010 ranger bed crossmember replacement
oh10ranger
12
Bangor,Maine.
Ranger 2wd.4cyl
2010 ranger I just purchased has a broken front bed xmember,rusted out.Maine salt.
Replacing all.
oh10ranger
12
Bangor,Maine.
Ranger 2wd.4cyl
cut/drilled out old ones.glassbeaded bed.Had 3 made/bent at a local sheet metal shop.Bare.Still have to modify them to fit.
used 16ga. and the front is also d.i.y. Cost under 2 beans
oh10ranger
12
Bangor,Maine.
Ranger 2wd.4cyl
nobody has ranger xmembers,that I could find.
Grumpaw
1,504
Virginia
Ford Ranger XL
Stock
Stock
Stock 225/70/15
I don't count birthday's anymore...just happy to be looking down at the ground instead of looking up
Very nice job, well done.
Grumpaw
Somebody does make them, but I don't know who. We have done a few sets at work recently.
Although I'm not 100% sure we aren't modifying ones meant for a different application.
oh10ranger
12
Bangor,Maine.
Ranger 2wd.4cyl
grumpaw ,thanks for thumbs.adsm08 very interested on this.
I can give you specs if needed,but same question is why don't they make them
oh10ranger
12
Bangor,Maine.
Ranger 2wd.4cyl
Got 3 welded in place today,just gotta finish them.
Measurements of the front one is 5ft long,3"x3". and used 16g.
oh10ranger
12
Bangor,Maine.
Ranger 2wd.4cyl
Welded in some extra steel on the front one. used 3-2" pieces of same 16g steel.
oh10ranger
12
Bangor,Maine.
Ranger 2wd.4cyl
A little more info.
Front bed crossmember #1 towards cab.
Welded 2 pieces of Sheetmetal together. 5ft x3x3
Second xmember #2 from front
38"long with a 2"bend x 2 1/2" height.
Third xmember #3
38"long with a 2"bend x 1 1/2"height
Fourth x member #4
50"long with a 2"bend x 1 1/2"height
5th x member #5 is good.not replacing.
Other than the front one,the other 3 were bent at a sheet metal shop.
oh10ranger
12
Bangor,Maine.
Ranger 2wd.4cyl
Will have to do some bed repair before the last xmember is set
