2010 ranger bed crossmember replacement
oh10ranger
15
Bangor,Maine.
Ranger 2wd.4cyl
Old reply... Sorry, but ranger is going great its my daily ride in the summer months.Crossmembers,and everything still looks as pictured.
4 cyl,5spd,2wd,112000 on the odometer.
Rock Auto 5% Discount Code: BD8D9A3814E19D Expires July 5th, 2022
tbayfinn
Thunder Bay
Mazda B4000
Hello, I was thinking of just using galvanized square tubing for the 2nd, 3rd, and 4th crossmembers and attach them to the frame since Dorman doesn't seem to offer these replacement crossmembers. Any thoughts on that approach?
ericbphoto
Overlander in development
Forum Moderator
9,052
Wellford, SC
6"
Those are originally welded to the bed to give it structural rigidity from side to side. The square tubing may be a good idea. But I would recommend attaching it to the bed to follow the original construction.
tbayfinn
Thunder Bay
Mazda B4000
Sounds great, thanks. I will probably go with bare steel tube and POR-15 coating after welding.
oh10ranger
15
Bangor,Maine.
Ranger 2wd.4cyl
Yes i agree with your decision.Have fun with that project.My crossmembers still look like the day i finished them,course only been a year.
Jazzer
274
Indianapolis
Google “galvanized hat channel” used in commercial construction. A couple of years ago I found some hat channel the right size to replace the original crossmembers.
GaryS_098
West Chester PA
Ranger XL 2WD
Hello - have a 97 ranger, took the bed off to work on the frame. Wondering if you could just leave the crossmembers there and cover them with slightly oversized ones - larger in width and height, thickness of the metal - of course you would treat the existing ones prior to covering them. If your making the crossmembers you could oversize them so they are touching new to old.
Roert42
2,332
Kintersville, PA
Ranger XLT
4.0 SOHC
Nothing saying you can’t, but it would definitely be more work with a lower quality end result.
oh10ranger
15
Bangor,Maine.
Ranger 2wd.4cyl
Ranger has 121000,just as reliable as the 92 i had.
oh10ranger
15
Bangor,Maine.
Ranger 2wd.4cyl
Hello garys98,yes as mentioned it would work.
