2010 F150 XLT 5.4l cranks, no start, no codes in PCM, Gauge cluster, or GEM.
8,370
I checked this is on when i crank it. So go back and check the wire to the Crank sensor.
Then either PCM is bad or crank sensor signal is not making it to PCM
Not possible :)
Even if that second person JUMPS when they get electrocuted you are still missing if it was just key on spark or cranking spark
No, I can hold the screw driver and see the cranking spark. It 100% is possible because I have done it many times.
If I can hold the screw driver, and observe a spark to the head or block or intake, really any major metal part of the engine, while it is spinning over, that is an effective test of cranking spark. And I have done it many multiple times in my years of owning 2.9s. I can even assess the health of the coil and TFI on a 2.9 by the color and quality of the spark.
This. That's why I said to tap the crank sensor wires as close to the PCM as you can get and see if that same AC voltage is there.
The sensor is clearly generating a signal since you have voltage down at the sensor.
There are no other connectors in line between the sensor and the module, so a poor contact at an inline connector is ruled out.
Do you have access to an oscilloscope? Do you have access to a proper set of flex probes?
8,370
I was joking
What about the timing?
50/50 test does/tests BOTH
I was joking
True, it won't show timing, but it wouldn't show timing on a single cylinder engine either. A timing light would show both spark and timing, but not quality, and you need plug wires for that.
The ether test would show both.
But neither is relevant to the OP's issue at this point. The PCM already admitted it isn't firing the injectors OR the coils because it doesn't think the engine is spinning.
funguy26
11
Dilkon,az
Ford Ranger XLT
245/75R16
I check on the cricut for the Crank sensor tomorrow
funguy26
11
Dilkon,az
Ford Ranger XLT
245/75R16
I check the wire for the crank oms read is .01 for both. replaced the crank sensor again thinking is was a DOA. nothing still only cranks. thinking is a issue with the tone ring.
8,370
If tone ring was not close enough then you wouldn't have gotten the 0.5-1.0vAC reading on your meter that you have before
Crank sensor generates its own voltage
As Adsm08 said if you use sewing needles to pierce the Crank sensor wires(tap the wires) at PCM, then crank engine you should see the AC volts if crank sensor and tone ring are working
funguy26
11
Dilkon,az
Ford Ranger XLT
245/75R16
the reading is in ohms. .01 ohms from the PCM to crank sensor on both wires. not power I check the power there it nothing no power from the sensor.
8,370
OK, in an earlier post I thought you measured voltage at the crank sensor, my mistake
You found the issue, well at least the first main issue, crank sensor starts the ball rolling on all other PCM functions, its the Big Kahuna of sensors
funguy26
11
Dilkon,az
Ford Ranger XLT
245/75R16
I pull the timing cover off and found the crank shaft tone ring missing. I feel like idiot got a new one on the way. wedsday is when it should show up.
Teeth face away from the block.
funguy26
11
Dilkon,az
Ford Ranger XLT
245/75R16
truck starts now, I try filling up the cooling system I got water in the crank case with the oil its leaking out of the front main seal. I thinking the block or one of the heads have a crack. add water and water in the crank case.
8,370
