2006 xlt: always max heat
SparkyD
Washington State
A little back story: i took my truck in for the 'airbag inflater recall' and when i got my truck back it only blows max heat no matter the temp control dial. The fan speed works great. The stealership that did the airbag recall wanted to charge me to fix it so here i am coming to you guys/gals for help. Yes this happened a couple years ago. I'm a professional procrastinator. I'm thinking the tech must have just bumped something. I checked all the wires and vacuum hoses and don't see anything out of place. Any help is appreciated.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Does the motor try to move the door ?
Uncle Gump
Token Old Guy
13,454
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
These Rangers circulate coolant all the time through the core... temp is controlled with the blend door.
So I'm with bobby... the blend door is stuck... wiring or the actuator is kaput.
SparkyD
Washington State
When i removed the glovebox while installing my new stereo i tried to move it and it seemed pretty solid. Can i assume the motor is the thing on the right that has a long piece connecting it to the blend door?
SparkyD
Washington State
It seems to be vacuum actuated. Opens when the truck is turned off, as soon as i start the truck it closes
