2004 Ranger flatbed
Rock Auto 5% Discount Code: 7FA902352B4C01: April 5th, 2021
bobbywalter
TRS Technical Staff
1,017
woodhaven mi
FORD mostly
BIGGER
sawzall?
its awesome!
though i would not have given up as much departure angle. and needs a drawer.
Uncle Gump
Forum Moderator
3,281
Plano IL
Lead, Follow or get out of my way
Looks pretty stout...
Any idea what it weighs?
bobbywalter
TRS Technical Staff
1,017
woodhaven mi
FORD mostly
BIGGER
sawzall?
and stake pockets.....and rails for tie down.
sgtsandman
Aircraft Fuel Tank Diver
Forum Moderator
2,834
Aliquippa, PA
2011 & 2019
Ford XLT & FX4
4.0 SOHC & 2.3 Ecoboost
31X10.5R15 & 265/65R17
I work in fuel tanks for a living. Don't judge me!
Looks great! I agree, you need tie downs of some sort. I would also recommend mud flaps for nothing else than preventing thrown rocks.
josh1236
6
West Virginia
its awesome!
I’ll need to figure out something to keep the tires from rubbing when I’m off-road I kinda screwed myself on that one lol
josh1236
6
West Virginia
I have no idea honestly. I could carry the main frame of the bed then I welded on the headache rack and the plate on the rear end after I already had it on the truck.
Dirtman
8,434
41N 75W
It's up there.
It's down there.
Round.
I love you.
josh1236
6
West Virginia
I plan on cutting leftover pieces of my 4 inch channel for tie downs but the only place around here that I can buy flat bar is closed. As soon as I can get flatbar I’m adding side rails and I plan to run wood sides also. I’m going to order a set of mudflaps here soon it’s really bad about throwing rocks.
bobbywalter
TRS Technical Staff
1,017
woodhaven mi
FORD mostly
BIGGER
sawzall?
Little here little there...
Then your building crane mounts.....boom poles...roll-up dumper....
I love it.
Blmpkn
338
Southern maine
Ford ranger
2.3
Nice! I'm building mine in the next couple weeks.
BJSRNGR94
Rochester NY
Ford Ranger FX4
If you have any questions building yours let me know!
How much did the build cost? I'm on the fence about doing this to my 2007 fx4 level II.
Also how did you mount to frame? anymore pics would be super helpful!
josh1236
6
West Virginia
I had around $450 in steel and I probably had $700-$800 in it total. Mine has pieces of 2 inch square tubing that sit on the frame and I just drilled holes to line up with the holes that your factory bed mounted to. I think I used 3/8 grade 8 bolts and haven’t had any issues yet
BJSRNGR94
Rochester NY
Ford Ranger FX4
Nice!
you got any more pictures of the build? or the finished build from different angles? I didn't know the steel would cost that much. What thickness plate did you use? did you bend it all yourself?
Thanks for the help Josh!
