2004 Ranger 2.3 No crank, will start from roll start or crossing the solenoid.
puresin5187
Mitchell , IN
Ford / Ranger
2.3L 16 Valve Duratec Engine
235/75 R15
Need to know what the volts should be for the Red/light blue Wire leaving the ignition switch?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
There is only two voltages available. Full battery power or 5v sensor reference.
Soooooo given that the ignition switch is not a sensor, it should be the exact same voltage as the battery. (Hopefully +12.3 volts)
puresin5187
Mitchell , IN
Ford / Ranger
235/75 R15
battery is good and not every wire on the ignition switch has 12v or higher but im not really sure if i have the Wire that controls the starter but if the red wire with the light blue stripe Is supposed to have +12v then its extremely low
8,370
Yes, there is a red/light blue stripe wire that runs from ignition switch to fuse 21 in cab fuse box, fuse 21 should have 12v with key turned to START
Out of fuse 21 will be a white/pink wire that runs to clutch switch, above clutch pedal on the pushrod
Then out of clutch switch on a pink wire to firewall
At firewall wire can stay pink or change to tan/red in engine bay
But in either case it runs to the starter relay in the engine fuse box
Ignition switch(START)---------(fuse 21)-------(clutch switch)-------------(starter relay)
Cab fuse box is the SJB(smart junction box) which is the Body Computer
These have a known issue for corroded connectors, seen here: https://i1.wp.com/sparkys-answers.com/wp-content/uploads/2016/10/DSC09929.jpg
Connectors have a lever that you lift up on and that pulls up connector away from SJB so you can then pull it off the rest of the way
I would pull fuse 21, then with a grounded meter I would test both fuse 21 slots for 12v with key turned to START, one should have 12v
If so put fuse back, ignition switch and red/blue wire are OK
Then pull out starter relay in engine bay
With key OFF, with grounded meter test each slot in relay base one should have 12v, remember that slot
Then have helper turn key to START and PRESS DOWN clutch pedal, and test the other slots, another slot should now have 12v
Diagram shows automatic trans as well, it uses DTR switch which is not used on a manual trans vehicle
puresin5187
Mitchell , IN
Ford / Ranger
235/75 R15
Okay I checked fuse 21 It didn't have 12 volts with the key turn to start it got 0.40 volts at the highest. So I'm a little lost at this point on what my next step would be
8,370
And you tested both slot of fuse 21, only 1 should have 12v with fuse out
If so then the wire from ignition switch to fuse 21 is bad, or connector in SJB is bad
SJB Connector numbering seen here: https://www.therangerstation.com/forums/index.php?attachments/2008-ford-ranger-fuse-diagram-smart-junction-box-jpg.30179/
C2280A on the left then counter clockwise to C2280D at top right
In the diagram above you will see C2280B wire 27 should be the red/blue wire from ignition switch, it should have 12v with key turned to start
That goes to fuse 21 via connector then out of fuse 21 to C2280A wire 31 and out to clutch switch
puresin5187
Mitchell , IN
Ford / Ranger
235/75 R15
Straight from the ignition switch if I do voltage on the blue and red wire it is very low and sometimes even in the negative so is it something with the ignition switch? Cuz I just replaced it not knowing if it needed replaced but it was when I was having the initial problem with the PCM not powering up
8,370
Sure, could be ignition switch, new doesn't mean "it works" anymore, new means NEVER TESTED now-a-days
Unhook either battery cable and pull out ignition switch
When you have ignition switch out hook battery back up and test the Yellow wire(s) yellow wire has 4 connections in the ignition switch, only 1 is used to power red/blue wire in START
Its the B4 wire/connection
red/blue is on the STA connection
1990RangerinSK
1,312
Saskatchewan, Canada
Well, when your horse is suffering you shoot it, so that might be a step you would want to consider.
puresin5187
Mitchell , IN
Ford / Ranger
235/75 R15
This 2004 horse would easily put your 1990 to shame and would end up shooting itself due to the embarrassment should probably consider that
puresin5187
Mitchell , IN
Ford / Ranger
235/75 R15
Ok ill throw the old one back in and test again thank you, ill post update after i switch it back.
