2004 - 4.0 Rev Limiter ?
hlenhart
Had one on my 4 wheeler when I was 12 ....
I Certainly LOVE my 2004 4.0 Ranger after 20 years of a 1990 2.9 Ranger ...
the Issue is that at Exactly 90 mph, engine turns into a Dead & Dying Frog, must be some Computer thing which I know NOTHING about.
Any Simple Answers on how to turn OFF?
(not that I wanna go Over 90, I just want to KNOW what's Going On) THX
8,412
Last I read it was 100mph, and it's usually set for tires, most are not rated for above 100mph
Speed limiter not RPM limiter
I did read a few post that it can be 90mph speed limiter on Rangers
Check actual speed with GPS just to see if speedometer is accurate
2004 Computer uses OSS sensor on trans for speed, if you have different size tires it may "think" you are at 100mph when at 90mph
You can change Speed Limiter with Ford software, maybe Forscan can do it, have a look on their forum
REV limiter should only be active in Park or Neutral, or under 5mph, its 3,000rpm
MarkDonovan
You can purchase a Diablo tuner. Removing the speed limiter and raising Rev limiter is are options. I run 4:89 gears I used it to get my speed back in line. On my 2WD Ranger I did a top speed run and lost courage and lifted at 126MPH. At least that's what my GPS recorded.
Diablo Sport
alwaysFlOoReD
5,786
Airdrie, Alberta, Canada
’97, '06
Pontiac, Dodge
2.2,5.7
I've hit the rev limit of about 5,000 rpm with a 4.0l in an old ranger. I think there is a vid of it hitting the limiter in my moderator profile.
Uncle Gump
Boomers gotta Boom
TRS 25th Anniversary
15,379
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
That's a good video...
Rick W
October Truck of The Month
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
