2004-2008 f150 2wd front brake upgrade.
Mightyfordranger
156
Ohio
2.9
3in
Clean your room before you criticise the world.
Ok now while this is still fresh in my in my head I'll get it out for the next guy.
This is to change the front rotor design of a 2004-2008 generation f150 that is 2 wheel drive, for the 4 wheel drive cheaper rotor.
First here is a simple kit with everything in one.
Now at the bottom of this pages description is a list of individual part numbers if you want to mix and match your own like I have.
I have copied and pasted each of them below for you in case this company goes under or anything of that nature a simple Google search should get you to a seller.
124.65902 is just the hub
124.65901 is just the hub nut
120.65100 is just the listed rotor
120.65128 is all in one kit
Here is the cheapest I could find just the hub.
and here is just the nut. Keep in mind this nut must be replaced every time that the hub is removed.
I will finish this thread once my parts show up and I'll post pictures of what it looks like for all you guys.
Pros for this kit are.
Made of forged steel instead of cast iron like rotors are.
Cheaper to replace rotors when needed.
