• Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' the posts that you read.
2003 V6 3.0L Auto/RWD Ford XL tapered roller bearings torquing specs?
Dibs294
New member
TN
Ford Ranger XL
I don't have much experience with tapered bearings, but have schooled myself so here I am requesting what I need from you gurus of wisdom, haha. I was wondering what the torque specs are. I have a click torque wrench to use and I'm needing to know the correct torque and also...if I need to put the wheels down for final torquing adjustment for this particular truck and bearing type.
Rock Auto 5% Discount Code: 4FF3E9EEA14805 Expires: October 1st, 2020
pjtoledo
Well-known member
496
Toledo Ohio
Fords
3.0 2.3
get outta my way, I'm falling!
tighten them while hanging in the air, no weight allowed.
keep wheel rotating while tightening
there are several opinions of how to do this, I recall the manual goes something like this:
tighten to 21 lb/ft, (that fully seats the bearings) 28.5 Nm
loosen 1 turn
tighten to 17 INCH POUNDS, that ain't much! 2Nm
EDIT:
that's what the manual says, I usually go just a bit tighter on the final step.
I do not grease the spindle stub, prefer to keep it dry between the stub and inner race to prevent
the race from slowly rotating on the stub.
ericbphoto
Old Redneck just wingin' it.
Forum Moderator
3,275
Wellford, SC
6"
I think the second torque is around 15-20 in-lbs. I know its in-lbs, not ft-lbs. I do it by feel and hope for the best.
