InsaneRedRooster
- May 16, 2012
- 1
- Ford
Hi all, this is my first post here but I read post's here frequently
Anyways I recently converted my 2003 edge front grille to the 98-00 style and thought I would do write up for anyone interested
Here's how the truck looked for a long time, the 98-00 grille on the newer style header Panel (I didn't like that much).
The new header panel, headlights, and corner lights (bottom bar night shaded) straight from the junkyard
A quick coat of flat black before it goes on.
One badass Mexican cleaning my lights.
My grille, i followed the write up in the tech library for the color change on the oval.
The old header panel and lights removed.
My truck was in a front end collision of some kind as far as I can tell, The forwardmost crossmember is badly bent and to fit the header panel we had to realign the bumper slightly to compensate for the damage Throwing everything off. I doubt if your front end is in good shape that this step would be required. The only modification needed to be done to the header panel is the removal of the center bracket(or just leave it at the j/y.
The damage to my crossmember that's had me irritated for the last year. How can I fix that easily? I don't have access to a torch so i think heating it is pretty much out of the question.
Moving on the panel Fit like a glove after moving the bumper down some.
The finished product. I wired the bottom bar light as the blinker and the little corner lights aren't doing anything right now, I'm not sure why but Ill either wire them into the blinkers or the headlights.
Anyway you guys tell me what you think, I like it more than most of the newer styles
