al881
- Jun 21, 2014
- 0
- Massachusetts
- Ranger
- Engine Size
- 4.0
Good day everyone.
I have a very strange problem.
I have a 03 Ranger, 188K.
I just completed a transmission filter change, and also purchased a new battery.
I drove it up and down block to make sure all was Ok, went out one week later, engine won't turn at all.
A starter was replaced last November, as well as plugs and wires; all a while back.
These last few days, I have done the following:
1. Made sure the inverter or kill switch was pressed in (passenger side
2. Checked to hear if the fuel pump made a noise. (Wife says yes)
3. opened up internal fuse box, ohmed out all fuses. Looks good.
4. Under hood , drivers side: I swapped relays and checked fuses. I even tapped the relays.
5. I read my alarm system diagnostic document. Followed instructions and looks OK.
6. I have a code reader. (There is no engine light on). No codes found.
7. Lights illuminate on dash OK
8. Does have gas, though a little low; but it's up above empty line.
9. Battery voltage looks to be 13 volts. 13.5 I believe
10. I tested alternator (but not sure why I would if the engine is not cranking)
Wire going back to batter is OK.
11. I took broom handle and banged the starter a few times.
12. Someone said smack the fuel tank a few times, but there is shield around it so I'm not sure this will help.
I think that is it.
I'm running out of items.
2 items remain.
>There is some sort of switch block under steering column that could be replaced. Not sure how to test.
>Some posting on the internet said that some "alarm card" under the steering column may need to be re-programmed for the anti-theft. Anyone hear of this before?
I have not retried a jump start.
There was one item I remember. The day I changed the tranny fluid. I re-started truck and when I turned key, engine did nothing. So I thought it was me and I re-tried start and it worked. Then I went on my way starting and stopping truck (in the drive way)
Next week, turned key. Nothing. Dead. No crank. No click!
Anyone have any other ideas?
Thank you
I think that is it.
2 items remain.
Thank you
