SD-Ranger
- May 25, 2021
- 0
- San Diego, CA
- Ford Ranger
I've spent a lot of time searching for the fix to this and haven't found a solid answer. 2003 Ranger 3.0 with 145,000 miles on it. Idle at low engine temp, the oil pressure gauge is fine, right in the middle. After engine gets to temp and driving, pull to a stop and at idle the pressure gauge flickers back and forth. Once a load is put back on the engine it goes away. I am aware that this is a dummy gauge and when the PSI drops below 8psi it gives a low reading.
Truck runs fine, does not leak any oil, does not burn any oil and no audible knocking from the engine.
What I've done so far -
- New Cam Position Sensor @ 140,000 miles
- Replaced Oil Pressure Sensor
- Using heavier weight oil - 10w-40
What I've seen as possible fixes:
- Checking the electrical grounds on the sensor. (don't think this is the issue but possible)
- Install a oil cooler on the truck, someone on YouTube fixed the problem this way. Said the oil gets thinner as it gets hotter and sends a low pressure signal. Makes sense but expensive and time consuming to install.
- Possible cam bearings worn
-Possible low idle/stall indication sending a false signal
Looking for any help with this or a definitive answer to get this corrected. Some say to just ignore it but I'd like to exhaust all solutions to prevent any major engine damage.
