Garbot2002
- Feb 26, 2023
- 1
- Virginia
- Ranger Edge
2002 Ranger XLT 8.8 28 spline axle housing. ALL new internals axle 0 miles.
Yukon Gear & Axle (YDGF8.8-28-1) Duragrip Differential for Ford 8.8 with 28 Spline Axle
Yukon Gear & Axle (YG F8.8-411) High Performance Ring & Pinion Gear Set for Ford Differential, ford 8.8 in 4.11 ratio
ZA F880035 [35026] Rear Axle Ford Ranger, LH, ‘99-’05, 7.5” & 8.8”, 30 1/4”, 28 spline 1551H steel 20% stronger OEM
ZA F880036 [35027] Rear Axle Ford Ranger, RH, ‘99-’05, 7.5” & 8.8”, 27 1/4”, 28 spline 1551H steel 20% stronger OEM
Yukon Gear & Axle (YSPBF-023) Outer Replacement Oil Slinger for Ford 7.5′′, 8.8′′
Ford Racing M-4216-A300 8.8" Ring Gear Bolt Set, (Pack of 10)
Allstar ALL72155 Differential Pinion Nut for Ford 8.8" and Standard Ford 9"
Differential
Yukon Gear & Axle (SK CSF8.8) Crush Sleeve Eliminator Kit for Ford 8.8/7.5
Differential
Yukon Gear & Axle (YK F8.8-A) Master Overhaul Kit for Ford 8.8 Differential
Yukon Gear & Axle (OK 3-QRT-Conv-A) 80W90 Conventional Gear Oil with
Positraction Additive - 3 Quart
Yukon Gear & Axle (YSPCC-010) C/Clip for Chrysler 8.25", Ford 7.5", 8.8"
Ford Racing outer axle bearings seals.
$500.00 will travel some if need be, cant ship. thank you for looking
Yorktown, VA
Differential
Differential
Yorktown, VA
