2002 SOHC smokes after warm up.
#1 Ford Fan
8
Puyallup, WA
Ranger Edge 4x4
Hello, new to TRS forums. I have a 2002 SOHC 4.0l that smokes after it warms up and wondering what it could be. It seems to me that if the rings were bad it would smoke all the time, cold or warm? I put a used engine in the truck while waiting to rebuild the original engine. The donor truck didn't have an EGR system so I swapped the intakes out from the original. Could oil be getting in through the PCV or somewhere else? Or is the engine just wore out? I heard it run before I bought it and it didn't smoke. Any tips would be appreciated.
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
What color smoke?
#1 Ford Fan
8
Puyallup, WA
Ranger Edge 4x4
Blue, smells like burnt oil. It goes from no smoke to a lot of smoke pretty quick. Thanks
rusty ol ranger
Im a Jeep guy now.
7,419
Michigan
177 CID
Probably rings. Could be a bad PCV. If its just a "get me by" engine untill you get the other one ready to rock id just run it.
8,369
+1 ^^^
Welcome to TRS :)
Blue smoke is oil
Grey is fuel
White is coolant
The blue smoke will foul O2s and Cat converters, so minimal use is best
Yes, rings or Valve guide seals
Valve guide seals are more likely because of the delay in the smoking, when engine sits the oil in the upper engine/valve covers drains back down to oil pan
On start up new oil is pumped up to the rockers/valves and starts to get sucked in thru the leaking intake valve seals, so a few minute delay
Just pull out the PCV valve and have a look, if its fouled with oil then install a "Catch Can" its not hard to do
And this would point to rings being the issue, excessive Blow-By
And synthetic oil will smoke less than regular oil, but its expensive
ekrampitzjr
1,057
Virginia
Out of curiosity, how many miles on the truck/engine?
#1 Ford Fan
8
Puyallup, WA
Ranger Edge 4x4
Hi, thanks for the info. I was afraid that would be the problem. The guy I bought the engine from said it had about 70k on it but I was suspicious. It has an average of 160lbs. of compression (that's the first thing I checked) but a couple of fuel injectors were clogged with gunk so I started to lean towards the PCV valve but that was just wishful thinking. I wont be running it like this for sure. Its a second ride for me so I think I will step up the plans to rebuild the original engine. I only paid $350 for the engine that's in it now and other than some fluids and a few gaskets, it didn't cost me too much. Buyer beware right. Thanks a lot for the help guys, I appreciate it very much. I'll post my project when I get a little further on it. It should be a nice little truck when I'm done. Take care.
#1 Ford Fan
8
Puyallup, WA
Ranger Edge 4x4
Hey all, Just a little update on my project. I got my original 4.0 L rebuilt but having the same issue that I had with the temp engine, IT SMOKES. After it warms up a bit it smokes. I have a question, I had said before that I used the intake from the EGR engine because the temp engine didnt have EGR. I used the same upper intake on the new engine. Is there a difference between the EGR and non-EGR intakes? One of the vacuum ports is in a different spot but thats the only physical difference I saw. Are they the same internally or not? Its the only thing I can think of. Any help would be great, Thanks.
