- Apr 13, 2009
- 5,093
- Calgary, Canada
- '91, '80, '06
- Ford, GMC,Dodge
- Engine Size
- 4.0,4.0,5.7
- 2WD / 4WD
- 4WD
Yes to a "how to fix this".
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Doodys will take an absolute beating and keep running. The older ones really impress me at times, and it seems like the only times they give up are after bad enough accidents or rust.The fact that it's running strong and doesn’t seem to need anything more major than a set of tires is all positive in my book.
It wasn’t “that cold”when I started it today. Ambient temperature In the 70’s. It’s June and I’m in South Carolina. After 3 or 4 minutes, it still wasn’t perfectly smooth.I'm glad you found one! In my experience most diesels are a bit tougher to start in the cold. When I first got mine it sounded like a drag car with blower surge for about a minute when I started it cold (near-zero temps). I adjusted the timing and it helped a lot. I think timing is all taken care of by the computer in yours, right?
When I replaced my fuel filter, I prefilled it with straight injector cleaner. I read about it in another forum; the idea is you run it for a little bit so the lines and injectors are full of cleaner and let it sit to hopefully dissolve crud. I don't know if this process would apply to the PSD, but maybe something to look into.
Another place to look is the glow plugs. I know they're a somewhat common issue in the IDI trucks and when a couple quit working it's harder to start cold. Also, the IDI guys say to use only Motorcraft brand glow plugs as the others swell over time. If it gets too bad the tip breaks off when you try to remove them. I remember a couple of mine being bulged. Not sure any of that applies to the PSD.
Good luck with your wiring. I lucked out on my used stuff so far being mostly unmolested. I did have to redo the trailer plug socket on my F250 this weekend and cut out a lot of those cheesy knockoff Scotch-Lok splices. It used to belong to a salesman for a trailer company and was used to pull a trailer to trade shows and stuff. It's an XL, the only options are AC and a radio, and he said he had to beg his boss for those. The brake controller pooped out on me towing our trailer full of stuff when we moved from ND to FL in Iowa. The truck nearly mated with a minivan on a freeway and I was a lot more careful after that. Not that tailgating was an issue, I did very little passing at 60MPH. I replaced it with a Redarc and it worked fantastic until one of those splices got corroded and it wouldn't "see" the trailer brakes any more.
I could check on that. I'll measure the thickness. I wonder if NAPA still does that.I don't see that much of a ridge on that rotor, could probably be fine to have them turned. If you know someone that still has a lathe.
