2002 3.0 power steering pulley
omgitzjojo
dunnellon, Florida
ford ranger
Is it possible to remove power steering pulley from truck without taking out the entire pump? There's a little play in the pulley and i think thats whats causing my engine vibration
ericbphoto
Overlander in development
16,580
Wellford, SC
3.0L
6"
If you really have excessive play there, its bad bearings. Replace the pump. That pulley is very, very firmly attached to it’s shaft.
omgitzjojo
dunnellon, Florida
ford ranger
The pump isn't bad. There is no turning or steering wheel issues. Just a pulley that you can hear smack metal at 2-2500 rpm
omgitzjojo
dunnellon, Florida
ford ranger
would anyone happen to have firing order for 02 ranger edge 3.0?
Blindmullet
7
Florida
Yes, the puller is usually available as a loaner at the parts store. I would think the pump is bad.
omgitzjojo
dunnellon, Florida
ford ranger
go to 1:50 seconds thats what my end play is. Tell me what you think.
ericbphoto
16,580
Wellford, SC
3.0L
6"
That end play should nor be causing a noise like something smacking on metal. The belt is under enough tension and moving fast enough that it should keep the pulley aligned where it needs to be. I would be looking for other problems. Check the tensioner and idler pulleys for play.
Do you have air conditioning? It could be the A/C pulley or clutch making noise. Maybe you could post a video (post to YouTube and just put the link here) so we can hear what's going on.
omgitzjojo
dunnellon, Florida
ford ranger
sounds more like a grind maybe. and i do have ac
ericbphoto
16,580
Wellford, SC
3.0L
6"
omgitzjojo
dunnellon, Florida
ford ranger
look at this... Could this cause engine shake though?
omgitzjojo
dunnellon, Florida
ford ranger
idk what that is. Piece of metal. It looks like it bolts to something.
