- Jul 31, 2016
- 3
- Mass.
- Mazda B3000
- Engine Type
- 3.0 V6
- 2WD / 4WD
- 4WD
- Total Lift
- Stock
- Total Drop
- Stock
Had a fuel leak running down the frame by the fuel pump. Found a tube - the largest (OD Approx.575.0”) had a bend with a pin hole leak. Replaced the pump several years ago with an Airtex. Purchased the Dorman Fitting Tool and replaced several fuel lines/connectors that looked rough while I had the bed removed.
The leaking line routes from the largest fitting/port on the Fuel Pump (Approx. 630.0" OD) to a Y Connector on the left frame rail. From the Y, it looks like one line runs Aft to the Evap Module(?) with the other running forward to the Fuel Filter.
I've been searching online, local Parts Stores, etc. trying to get a PN for a replacement Quick Disconnect fitting and a section of replacement tubing with no luck. The only lines connectors referenced for B3000 and Rangers are 5/16 and 3/8. Contacted Dorman to see if they had any info available and the Rep said they do not.
The current Quick Disconnect Fitting does not look bad after removing the damaged portion of nylon line from it. Am thinking to use rubber Fuel hose to connect to the pump and a barbed fitting to connect to the Y . Would like to keep the truck as original as possible and figured I'd post to ask a knowledgeable person what the deal is with this line before modifying it.
Would appreciate if one familiar with this line can educate me on this Fuel Line and shed some
