2001 Headlight housing
computersoc
I have a 2001 Ranger XLT 2.5L. Will these work since I see some reviews for others say 2001 is listed as working but needs modifications to the wiring. I just want something similar that is plug and play so I can swap them myself.
My current stock headlamps are too low even though they're aligned as high as they go. My high beams are basically what I'd expect out of a low beam.
If I install LED 9007 bulbs in these housings that I linked, will I get rapid flicker of the turn signal or other issues? Or will I need an adapter so it doesn't do that?
Uncle Gump
Token Old Guy
13,423
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Every time someone posts about new headlights... I find myself "shopping" for new headlights. My factory lights are still in great shape and I don't need a set but some of them are pretty cool.
I think the common thread with most of these aftermarket offerings is... it's a total crapshoot. They come broke... don't fit... they fogged up... needs rewiring... it's always something. I didn't look to close at the reviews for the ones you posted... but the C clamp thing looks pretty cool. I say... if you are going that route... be prepared to have to modify something and expect a lesser quality part then what the factory parts are.
If you decide to buy a set... be sure to review them. They seem a bit pricey... but current as far as design.
computersoc
Amazon has a good return policy so back they go if they are too much of a hassle. I'll update everyone on how it goes. Taking the headlight housing out doesn't look too hard. Anything has to be better than the stock lights.
kmbkk
Williamsburg, VA
Mazda B2300
im interested in these as well. Did you ever buy them?
