- Aug 7, 2007
- 38
- Farmington, Pa
- Ford F250 4WD
- Engine Size
- 3.0
I'm getting a free 93 Ranger, 2wd, Reg cab, 5 speed manual tranny, rear ratio unknown. Body is straight, never wrecked, but "it's been in the woods some".
The motor (he calls it a 2.0, but I am skeptical) is dead, according to the owner. Used to run last fall, but starter would freewheel where the ring gear is missing teeth (which means the tranny is coming out). He used to catch it in gear and it ran. Now it won't even do that, but I really don't care. With 275k on the odo, that motor is as good as gone, regardless whether it still runs or not.
Anyone ever put a 2001+ Duratec 2.3L into an older (93) Ranger (OBD1)and keep the OBDII operational?
I know I'll need the donor engine harness, computer, sensors, serpentine drive, (hoping to get its accessories). It's getting an electric fan. Curious if the newer PS pump is compatible with the steering rack. Surely the steering rack is the old-style, not like the rack/pinion on my 2000, but we'll see.
Hoping to get a fresher 5 speed to go with the motor as a package deal, ideally still bolted together with clutch master and reservoir. New clutch, if required. Cross-member different?
The electrical part doesn't scare me, but I'm concerned with the "gotchas" that I haven't even begun to really think about. Instrument panel may need swapped, with harnesses from the donor as well. Needing to keep an OBDII port in the cab for the Scangauge, so I'm wondering if any of the 96+ instrument panel clusters will fit? Definitely want a stock tach in that cluster.
I want to keep as much of the truck original as possible (low budget), but it does need ball joints and tie rods replaced. Figure on a new set of front brakes, new bearings and rotors, hoping the calipers are good. Haven't researched the calipers at all, but I plan on running 16" rims with low profile tires, probably 55's or 60 series, and I need good brakes. I'll consider replacing the spindles if I can mount better, but stock, calipers with larger rotors. Springs are optional, we'll see how bad they are.
I also want to swap in a 4.10 LS 8.8" rear, 28 spline is fine, but I wanted the larger diameter 10" drums, so I'll look for that at the JY. Pretty sure it's got a 7.5" (3.73?) now. Probably keep the original leafs, maybe add traction bars if it turns out to be a wheel hopper when I power shift.
This will be a DD, not off-road at all. I like the HP/TQ #'s the new generation 2.3's make and really don't want to 302 or 4.0 swap into this thing. I figure with the 4.10's and small tires, it ought to run pretty decent around town.
Anybody have any experience with the fuel system? I figure I MAY have to convert from return to returnless, unless somebody knows differently. I will get as much off the donor as I can, but I need to know what to grab. The JY won't let me take the whole donor away, strip it, then bring it back. I expect to get all the EVAP system parts to keep the OBDII happy, but don't know if that includes the plastic fuel tank. Pretty sure I'll need the modern fuel pump assembly. Should match the cluster's fuel gage.
I'll be interested to get any knowledgeable feedback on what's gonna bite me if I don't pre-plan properly.
FYI, I don't weld, so the exhaust will be clamped up, exiting before the axle. Might opt to get it welded up after it fits.
I thrive on electrical stuff, but I need 93 wiring diagrams (searching for those).
I don't forsee any show-stoppers, unless someone tells me differently.
And the wait begins.......the guy won't let me have it until he gets the bed and cab emptied out.
