BL84
- Oct 11, 2020
- Reaction score
- 0
- Location
- Chester1bl!
- Make / Model
- Ford Ranger
- Manual
Hi, I have a 2000 Ranger 2.5L manual tranny, I had replaced the fuel pump and sending unit to get it to start up again after sitting for a couple months. It then would start but anytime you revved it up it would die when you released the throttle. I have since replaced the MAF sensor and housing, the IAC, the TPS (and cleaned the throttle body housing), the intake manifold gasket, the EGR valve and tube, the O2 sensors and the vapor cannister purge valve. Now it barely starts and only stays running when the gas pedal is pressed but it doesn't sound like it wants to be running when you do that, it dies when you release the gas and it even if you keep pressing the gas pedal it seems to peter out and die. I replaced some of the vacuum hose that was old as well but went through and checked all the connections, and everything seems to be in order, it doesn't have any codes stored or pending, but I can't get any live data because it won't run long enough, I am kind of stumped at the moment.
