2.5L ('98-'01) 2000 Ranger won't start and run without foot on the gas
BL84
Chester1bl!
Hi, I have a 2000 Ranger 2.5L manual tranny, I had replaced the fuel pump and sending unit to get it to start up again after sitting for a couple months. It then would start but anytime you revved it up it would die when you released the throttle. I have since replaced the MAF sensor and housing, the IAC, the TPS (and cleaned the throttle body housing), the intake manifold gasket, the EGR valve and tube, the O2 sensors and the vapor cannister purge valve. Now it barely starts and only stays running when the gas pedal is pressed but it doesn't sound like it wants to be running when you do that, it dies when you release the gas and it even if you keep pressing the gas pedal it seems to peter out and die. I replaced some of the vacuum hose that was old as well but went through and checked all the connections, and everything seems to be in order, it doesn't have any codes stored or pending, but I can't get any live data because it won't run long enough, I am kind of stumped at the moment.
Rock Auto 5% Discount Code: 7FA902352B4C01: April 5th, 2021
2,626
Welcome to TRS :)
I assume you also changed fuel filter when you did the fuel pump?
Check Vacuum when cranking engine over, should be about 2"-3"
If not then exhaust may be blocked or timing belt has skipped a tooth(low compression)
After only a couple of months the gas in the tank should still be OK
BL84
Chester1bl!
Welcome to TRS :)
Hi, thank you :) I did not change the fuel filter as it had not been that long and it had not had a problem starting or idling until I changed the intake manifold gasket and O2 sensors. The battery did not have enough charge to turn it over though until I put it on the jump starter if that gives you any ideas. I thought I would get a fuel filter tomorrow just to be thorough though, I need to have someone start it so I can watch the engine to see if anything is amiss, it definitely sounds like it is unhappy.
2,626
O2 sensors only work when they are heated above 650degF so are never used when starting, and if engine was cold then they are not used for the first few minutes of running
A vacuum leak in intake manifold gasket could cause slow start but would have to be a bigger leak
Partially clogged fuel filter wouldn't cause slow start but would cause limited RPMs and low power
If you can get your hands on a vacuum gauge($20) then I would see what that tells you, one of the better diagnostic tools for gasoline engines
Locotomb
62
Puyallup, WA
2.3l
6inch custom fab lift/86
Bagged 3 inch custom drop beams 88/89 Custom triangulated and step notched rear
35/12.5/r18
Everything looks better lower
I’m with you Ron, Gasket leak. Or, maybe even a stuck closed IAC valve.
BL84
Chester1bl!
It actually is the cat that is clogged, I removed the upstream O2 sensor and it started up and ran no problem, I am sure that cat was on it's last leg anyhow. At least it makes sense that was driving me crazy...
2,626
Good work
Thanks for the update and the FIX
