2000 Ranger 4.0 will not start but cranks over Help!!
gcbokash
Bridgeton
ranger xlt
My ford ranger 4x4 2000 with 4.0 just died going down the road. Check engine light is on. Sprayed starting fluid into intake and it started for several seconds so I figured it was a fuel pump issue. Replaced fuel pump and still did not start. Checked relays to fuel pump and they are good. Jumpered across fuel pump relay and the fuel pump runs and there is fuel pressure at fuel rail but truck does not start. Replaced the ECM and truck still does not start and not sure what to do next
rumblecloud
1,322
48022
Ranger Splash
1-1/2 inch front leveling
Stock
What's the worst that could happen?
Inertia switch? Not sure where it is located on your model. Usually in the passenger side kick panel.
It could be a lot of different things but this one is easy to check.
Others will have more to offer.
EDIT: have you pulled any codes?
Welcome to TRS BTW.
gcbokash
Bridgeton
ranger xlt
Can't be inertia switch if I jumpered relay and pump starts that proves inertia switch is good. I have tried three computer code readers and cant get it to communicate
Eddo Rogue
2,535
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Mine did that once and it was the fuel pump fuse. its a mega fuse 30amp. Still blows once in awhile if I jar the truck off roading. keeping spares until I have time to figure it out.
rumblecloud
1,322
48022
Ranger Splash
Stock
So, no fuel. Are the plugs wet?
Odd that it just stopped with no prior symptoms.
stevelaw2000
6
Texas
Check the ground wire, clean battery terminals. Just an idea. The ground wire could be loose. If you can't communicate with the ecm. I am no mechanic though. Good luck.
gcbokash
Bridgeton
ranger xlt
when I had the schrader vale depressed I jumpered fuel pump relay and fuel shot out
superj
3,592
corpus christi, texas
ranger edge
182 ci of tire shredding power
2, so far
235s
drives a stick shift ranger
that doesn't mean its to the correct spec though. fuel pumps can still put some fuel in the line but not be up to the pressure the system needs to spray into the chamber properly.
put a gage on that valve and see what it reads
StewieNC
North Carolina
Check the crank angle sensor. It is on the front end of the crankshaft, pretty easy to replace.
Rick W
October Truck of The Month
Vagabond Video
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
